TPC issues
battanc
Level 3
Level 3
does anyone have any idea about the automatic power calculation (TPC) of the WLC?
I have a WLC-4402, version 7.0.98 (old, but I can not update).
In the configuration, there is a parameter (Antenna Gain) which should allow the algorithm to consider also the type of the antenna, but it seems irrelevant.I mean: I can use an Antenna Gain of 0 dB or 20 dB, but the power level never changes (obviously waiting for at least 10 minutes for recalculation)
Some suggestion?
0 Replies 0
