Enabling Web Interface
alexandre.raffin1
Community Member
I have 2 Cisco Aironet 1700 Series. I have been able to access the web interface on both of them at some point. However, after unplugging and plugging back the first one, I couldn't access the web interface anymore.
I can access them through ssh. I checked both configurations and they are nearly the same. The results are the same except for a few differences :
command 1: show run | i ip http
result (same for both):
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
command 2: show interfaces
result (just an extract):
Dot11Radio0 is up, line protocol is up
Dot11Radio0.11 is up, line protocol is up (only for the first AP, the one i can't access the web interface)
Dot11Radio1 is up, line protocol is up
I tried:
reload
AND
while in global configuration mode: ip http authentication local (also tried enable)
ip http server
Also, the Cisco, Cisco user exists for both.
When running nmap, the state of the port 80 is sometimes filtered instead of open. Also, I can sometimes be prompted to enter a username and password but Cisco, Cisco does not work.
Any command I could run to pinpoint the problem? Any command I should run to enable the web interface?
Alexandre
0 Replies 0
