TPC Power Transalations
nshoe18
With the newest version of code on the controller, I have seem to lost the power translation levels for the Transmit Power. We typically try to set the APs on controllers we deal to go no lower than 50%, Power Level 4. On the old 6.x version of code this was typically 11 for Minimum Power Level Assignment. Now it has to be between -126 and 126. Does anyone know which power level would equate to 50%?
I guess I could just figure out what 50% is of the -126 and 126, correct?
2 Accepted Solutions
George Stefanick
Keep in mind on UNII2, UNII2E and UNII3 the out put is different depending on the channel..
UNII 1                                                 UNII 2 / 3
1 = 11 dBm / 12.5 mW                          1 = 17 dBm / 50mW
2 = 8 dBm / 6.25 mW                            2 = 14 dBm / 25 mW
3 = 5 dBm / 3 mW                                3 = 11 dBm / 12.5 mW
4 = 2 dBm / 1.5 mW                              4 = 8 dBm / 6.25 dBm
Correct.  Sorry, I should have mentioned it wants a whole interger value.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
6 Replies 6
Stephen Rodriguez
IIRC, this is for setting the maximum and minimum power for RRM.  What you would want to do is convert the dBm 20,17,14 etc to the actual mW value.
20dBm = 100mW
17dBm = 50mW
14dBm = 25mW
11dBm = 12.5mW
8dBm =  6mW
5dBm =  3mW
2dBm = 1.5mW
-1dBm =  0.8mW
So, what you would want to set in those fields is the appropriate dBm/mW values.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
ok so I will be setting the controller to be 12mW since it will not accept 12.5, correct? That looks like the number I want.
HTH,
Steve
George Stefanick
UNII 1                                                 UNII 2 / 3
That's a very good point George. I overlooked that in our network and I'm phasing out the UNII 1 band on our APs. We can live without those four channels to increase our 5GHz range.
Yea, its those fine detals you know ...
I blogged about it here
http://www.my80211.com/cisco-wlc-labs/2009/10/30/what-you-need-to-know-about-tx-power-and-80211a-5ghz-on-a-ci.html
