Tracking Guest Wireless Usage with NCS?
Carl Harbeck
Level 2
Level 2
Hi all,
Is this preferred method to use a syslog server? Does anyone know if this will give you the account name and MAC address of the PC used to access the guest network?
blakekrone
Level 9
Level 9
NCS will allow you to run a history report or current report that tracks MAC addresses with guest user names. You can also have scheduled reports emailed to you at a certain interval.
Using a generic syslog won't work as easily, you'd have to link the syslog with a DB of some sorts.
blakekrone
Level 9
Level 9
Yep, thanks - figured that one out after poking around a little more
