Trustpoint for Cisco 9800-80 Wireless Management Interface
Jerome N
I am attempting to create a WMI on c9800 controller. I had used the pre-installed MIC (CISCO_IDEVID_SUDI) on 16.10.1 but upon upgrading to 16.12.4s, I am now unable to use this trustpoint.
Via the Gui, I no longer have a list of trustpoints to select from even though they are still present under PKI management.
Via the CLI, attempting to configure with "wireless management trustpoint" command, I receive the following output:
% switch-1:dbm:wireless:Default Cisco SUDI trustpoint name is not allowed
Also, does it matter whether I create a SSC or use the MIC. What's the difference?
Could anyone assist? Any help is appreciated.
Nicolas Poirier
Level 4
Level 4
See Grendizer answer below
Grendizer
Check the 9800 best practices doc, https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-743627.html in it, you will see you need to use:
c9800(config)#no wireless management trustpoint
c9800(config)#wireless management trustpoint CISCO_IDEVID_SUDI
Jerome N
Thanks for your replies.
I actually found what seems to be a bug - CSCvr03501 - On 9800-40/-80/-L GUI, wireless mgmt interface should only list non-default LSC in cert menu
Appears the option should be blank as MICs are used a default. If i go to Monitoring --> System --> Wireless Interface then it informs I'm using CISCO_IDEVID_SUDI
Adding this info just in case anyone else needs some answers.
Yet to adopt an AP to ensure it does work.
