Two SSID´s
jmanzur1683
Visitor
I have an cisco  AP 1242, with only one SSID. On that SSID I have 20 Laptops.
If I create a new SSID, and move 10 of that 20 laptops in the new SSID could be better?
Regards.
George Stefanick
Hi Jorge,
The short answer is no if they are all using the same radio (802.11g) for example. Because all the devices are sharing in the medium. So even if you added another SSID these devices are still on the same channel / radio thus sharing the same medium.
However, if you are curious, your ap does support 5 ghz (802.11a). You could broadcast the same ssid on the 5 ghz side, and attach 10 of your devices to the 802.11a side. This is of course if your devices support 802.11a.
Unless you are pulling heavy video and data, in most cases 20 clients are fine on a single access point.
I hope this helps.
