Cisco 1941W issue accessing WLAN ap website
neil.levien
Hi All,
I'm having issues opening up http interface for the wlan on a Cisco 1941W. All I want to achieve with this set up is one SSID being broadcast that allows mobile devices access to the LAN. A lot of the SSID/Wireless set up has been removed due to testing but this is where I'm at right now.
I've tried it on multiple workstations, browsers, access from different subnets.
Attached is both the config of the router and the ap. I've also attached a screen shot of the error message I get after authenticating to the ap web site.
The router is set up as required and is working as expected.
Thanks for the help in advance.
Neil
Surendra BG
ok!! First thing.. ur hitting the AP801 GUI enter button bug.. here is the doc that i hv written which may help u!!
https://supportforums.cisco.com/docs/DOC-13047
Then follow this vidoe blog and this will help u getting the config issues!!
https://supportforums.cisco.com/videos/2500
Please reply to this post if ur facing any issues!!
Surendra
Surendra BG
9 Replies 9
Scott Fella
Have you looked at this link.  The wierd thing I saw from your ap.jpg is that it shows Cisco - OfficeExtend AP Login.  It should not show this.
https://supportforums.cisco.com/thread/2028286
-Scott
Hi Scott,
I have followed that thread and also the sample config from Surendra - the only thing I need to redo to match that exact config is modify the vlan/bridge group and switch the internet interface from gi0/0 to gi0/1(which I can't do until I'm onsite next week). Althought I'm not confident that will resolve the issue.
Neil
Just keep us posted. Those are important.
Scott Fella
Sent from my iPhone
-Scott
Surendra BG
Surendra
Surendra BG
Surendra,
Wow... I would of never know.  I have an 871W and a 1941W and never ran into those issues, but now I know just in case.
-Scott
Scott...
871 is not affected! but 1941W is nothing but the same AP which is integrated inside the 861/81/91 W (its AP 801)
Surendra
Surendra BG
Okay... thanks for the heads up!
-Scott
Hi Surendra,
Thanks that is indeed the problem.
The ap is running: Cisco IOS Software, AP801 Software (AP801-K9W7-M), Version 12.4(21a)JA1
I have another question: I can't find the firmware for the ap by searching from: http://www.cisco.com/cisco/software/navigator.html?mdfid=282774241&flowid=715
Is there another product I can use that will work?
Neil
Ok - problem has now been resolved.
Thanks for the help Scott and Surendra.
