Two Standalone APS 2702
in our office i have to configure  two standalone APS of 2702 series with one ssid
2 Accepted Solutions
Here is the configuration guide for autonomous AP configuration : http://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3/cg15-3-3-chap4-first.html#pgfId-1201529
note : that the 2 APs must be on the same subnet and their signal overlaps with each other. They should have the same security settings, same SSID but different Channel.
under radio configuration you can select channel:
  • Channel—The default channel setting for the wireless device radios is least congested; at startup, the wireless device scans for and selects the least-congested channel. For the most consistent performance after a site survey, however, we recommend that you assign a static channel setting for each access point.
– For the 2.4 GHz radio, the relevant options are Least-Congested, channel 1-2412, channel 2-2417, channel 3-2422, channel 4-2427, channel 5-2432, channel 6-2437, channel 7-2442, channel 8-2447, channel 9-2452, channel 10-2457, and channel 11-2462.
– For the 5 GHz radio, the relevant options are Dynamic Frequency selection, channel 36-5180, channel 40-5200, channel 44-5220, channel 48-5240, channel 149-5745, channel 153-5765, channel 157-5785, channel 161-5805, and channel 165-5825.
Thanks Mohanak,
Could you please post any links for the  configuration guides for this two Aps of 2702
