txPower setting of AP3802I in flexconnect mode.
grasshopp
Sorry for the newbie question.
Can someone give me a line by line instructions to change the txPower level of the 5Ghz radio? Or is there an easy GUI that I can use?
I have tried to follow the Cisco wireless access point configuration guide, but none of the commands work as expected in the command line interface.
This is what I have tried but I can't even get past the first line:
Config Terminal
Interface dot11radio 1
show advanced 802.11a txPower
config 802.11a txPower global 5
end
copy running-config startup-config.
Situation:
Only 5Ghz is allowed,
Minimum power necessary to connect in the room that it resides. (to limit power to other areas of the building)
We have only one unit and it is stand-alone hooked to the internet. (no controller)
Right now it is too hot and is above the threshold in another part of the building
Thank you.
11 Replies 11
Mark Elsen
                 >...This is what I have tried but I can't even get past the first line
  What happens then, what error do you get (e.g.) ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
it says there are errors in the command
Here is a Putty log:
And this is what I get if I connect through the browser. I have found no place in it to adjust the txPower.
Hi, Is this AP joined to any controller?
Good luck
KB
no we don't have a controller it is in Flexconnect mode
 - Then it still needs a controller to operate or else you need to run it in autonomous mode.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
We have two of these APs and the second one takes all the setting of the first one.  I thought that was what Flexconnect was for. would switching it to autonomous mode interfere with that?
                  >...these APs and the second one takes all the setting of the first one
 - If the first AP is the controller (too) , then check if you can change the needed settings over there.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
That is the one I am on.  I actually turned off the second one thinking that it may be interfering with the first one.
 - No , it will need to be online.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Arshad Safrulla
Hi Guys,
This AP is running in Teleworker mode. So definitely this needs a WLC to manage it. If you want to control RF related settings then you may need to do that from WLC (you can only select the channel width, channel selection and enable ac, n in teleworker mode). If not consider converting this AP to Mobility Express (3800 series doesn't support autonomous)
If you are not using OEAP, disable it under the All AP>>Flexconnect>>Office extended AP
