Unable to access Web GUI for Mobility Express Aironet AP 2802i
ahmedaburaihan
Hello Community
I have an Aironet 2802i Access point, I converted it into Mobility Express (Autonomous/Standalone) by transfering files from TFTP server. I configured settings using CLI Wizard, such as MGMT IP, time, country code etc.
I can ping AP Mgmt IP from my PC and vice versa.
The Problem is that i am unable to access WEB GUI to My Access Point (which is also funktioning as controller).
Thank you for an idea!
21 Replies 21
 - If you can not download the correct software image for the AP then you have  fatal showstopper ,
 M.
marce1000
  - Start from scratch and checkout this procedure :
          https://www.youtube.com/watch?v=6MxDGM7ilzE
 M.
@marce1000 I saw this, it didnt help. I configured everything OK.
  Ok , keep working on :
  -  Could you also try with both https and simple http ?
       >....I get no error, neither any https response code.
      So what does the browser then say in the end ? Is it site unreachable or something else ?
 M.
ahmedaburaihan
@marce1000
@RxTx
Guys thank you very much.
I solved the Issue, the problem was with my network segment. Changed my VLAN segment and it did work.
Well you were asked and you did say it was a very simple setup with them both in the same segment!
So I guess they were actually in different VLANs?
Also the AP port should either be access port or trunk port with native vlan configured for AP/ME management if you plan to use anything other than the management VLAN.
ahmedaburaihan
@Rich R no they were not in different VLANs/subnet, I assume the problem was with the browser. It worked after a reboot. I didn't configure anything.
