Unable to connect Cisco 7921 wifi IP Phone to cisco Access point
Vikrant Ambhore
Hi All,
I'm trying to connect Cisco 7921 wi-fi IP Phone to cisco Access point  but cisco IP phone getting authantication fail error can anyone suggest me, What could be the problem there,
I have attached Snap of configuration of my IP phone & below is my configuration of Wi-fi Access Point
Current configuration : 2353 bytes
version 12.3
no service pad
service password-encryption
hostname CiscoAPWiFI
enable secret 5 XXXXXXXXXXXXXXXXXXXX
ip subnet-zero
no aaa new-model
dot11 vlan-name Data vlan 1
dot11 vlan-name VOIP vlan 100
dot11 ssid Coinop
   vlan 1
   max-associations 25
   authentication open
   authentication key-management wpa
   guest-mode
   mbssid guest-mode dtim-period 1
   wpa-psk ascii 7 XXXXXXXXXXXXXXXXXXXX
dot11 ssid VoiceCoinop
   vlan 100
   authentication open
dot11 network-map
username XXXXXXXXXXXXXXXXXXXX password 7 XXXXXXXXXXXXXXXXXXXX
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
encryption vlan 100 mode ciphers tkip
ssid Coinop
ssid VoiceCoinop
mbssid
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root access-point
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.100
encapsulation dot1Q 100
no ip route-cache
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
bridge-group 100 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.100
no ip route-cache
bridge-group 100
interface BVI1
ip address 192.168.8.254 255.255.255.0
no ip route-cache
ip default-gateway 192.168.8.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
migilles
Which country are you located in?
Did you add the world mode (802.11d) command I mentioned?
Can also try using an open SSID without encryption.
7 Replies 7
George Stefanick
First, did you enter the correct PSK?
I always like to dumb things down. If you added an open wide network and connect the phone and it works. Then start to apply your security and see where it breaks. Also, can you connect a laptop to the Voice SSID ?
migilles
The config looks good, but if you have a -W model then you need to add the 802.11d / country code info.
The supported country codes are in the 7921G Deployment Guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf
Assume you have set the phone to AKM security mode, which is the mode you would need to set in order to use WPA/WPA2-PSK.
Hi Migilles,
Thanks for your reply
I got your document, looks like is good Thanks for post it, Now I am trying to configure Phone through GUI as per attached document (Page no. 71), but phone is not showing in device manager i think some drivers required for it,
I searched on net but didn't get anything for supported driver, can you help me for that, as per my think my issue will fix if I get driver 7 will try through GUI
migilles
Do you have a -W model phone?
Can see that under the battery on the phone.
If so you need to enable 802.11d / world-mode.
Below is an example that you would need added to each radio interface in the AP config.
Below is for US, replace with your country code as necessary.
world-mode dot11d country US both
For configuring the 7921 phone via USB, you do need the USB driver which is on Cisco.com. The driver is for Windows XP and 2000.
For Windows 7, you can set the device for XP compatibility mode.
Hello migilles,
I installed USB driver & Now I am able to access Phone by GUI, but still having same issue, I think  something wrong on Access point, Please help me,
migilles
Thanks it's fix
I played with it more time, & got success
