Unable to connect CIsco WAP AIR-AP1231G-A-K9 to the WLC model AIR-CT2504-K9
Zarar7
I have APs AIR-AP1231G-A-K9 and the Controller AIR-CT2504-K9. I am trying to add these APs to the controller but i am unable to discover the APs in WLC. i have configured the option 43 and DNS address but still not able.
i have the below console messages on the AP. Please someone assist me I am trying from last 3 days to figure out.
I am not wireless expert the guy who was managing these APs has left the company.
*Mar 3 21:34:36.944: status of voice_diag_test from WLC is false
*Mar 3 21:34:36.944: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 3 21:34:36.955: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 3 21:34:37.956: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 3 21:35:52.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.32.64.120 peer_port: 5246
*Mar 3 21:35:52.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Mar 3 21:35:53.916: %DTLS-5-ALERT: Received FATAL : Certificate unknown alert from 10.32.64.120
*Mar 3 21:35:53.916: %CAPWAP-3-ERRORLOG: Bad certificate alert received from peer.
*Mar 3 21:35:53.917: %DTLS-5-PEER_DISCONNECT: Peer 10.32.64.120 has closed connection.
*Mar 3 21:35:53.917: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.32.64.120:5246
*Mar 3 21:35:53.918: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
*Mar 3 21:35:53.900: %DTLS-5-ALERT: Received FATAL : Certificate unknown alert from 10.32.64.120
*Mar 3 21:35:53.900: %CAPWAP-3-ERRORLOG: Bad certificate alert received from peer.
*Mar 3 21:35:53.901: %DTLS-5-PEER_DISCONNECT: Peer 10.32.64.120 has closed connection.
*Mar 3 21:35:53.901: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.32.64.120:5246
*Mar 3 21:35:53.902: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
*Mar 3 21:36:57.577: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar 3 21:36:57.578: bsnInitRcbSlot: slot 1 has NO radio
*Mar 3 21:36:57.643: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar 3 21:36:57.909: %PARSER-4-BADCFG: Unexpected end of configuration file.
*Mar 3 21:36:57.912: status of voice_diag_test from WLC is false
*Mar 3 21:36:57.913: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 3 21:36:57.925: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
I am sure your 2504 has software that is no longer supporting 1231. Look at this table, 1231AP last supported in 7.0.x software version
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#56735
if you have later version of software in your 2504, I would not bother bring this 1231 AP. I will replace it with a later model
Rasika
*** Pls rate all useful responses ***
Leo Laohoo
What firmware is the controller running on?
As what Rasika has stated, the WLC needs to be running on 7.0.X.X.
patoberli
And even if you have an old enough firmware on the WLC, make sure you don't hit the certificate bug:
https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
