unable to connect SSID with WPA2 authentication
Noovi
Hi Guys,
i am having few scanner machines which are connected to SSID through WEP authentication.
But now i am moving these machines to new SSID with WPA2 authentication. i have created new SSID with WPA authentcation but machines are getting time out error on new SSID and reconnecting back to old SSID.
i have attached logs. Can you please help here to know issue?
 It seems to me that you need to disable Fast Transition on the WLAN:
11r AKM support verification failed on WLAN
Your client got associated and Authenticated more then once but it drops apparently due the fast transition enabled.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/80211r-ft/b-80211r-dg.html
Mark Elsen
 - Below you will find result from your debug file when analyzed with : https://cway.cisco.com/wireless-debug-analyzer/  Show All is checked :
TimeTaskTranslated
Connection attempt #1
Mar 22 10:30:00.031 *apfMsConnTask_5 Client made new Association to AP/BSSID BSSID c4:0a:cb:24:c4:31 AP 1126-1stFloor01-LWAP
Connection attempt #2
Mar 22 10:30:00.033 *apfMsConnTask_5 Client has entered DHCP Required state
Mar 22 10:30:00.033 *apfMsConnTask_5 Client has successfully cleared AP association phase
Mar 22 10:30:00.033 *apfMsConnTask_5 Client is entering PSK Dot1x or WEP authentication phase
Mar 22 10:30:00.033 *apfMsConnTask_5 Client expiration timer code set for 1800 seconds. The reason: Client is scheduled for session timeout deletion (wlan with webauth)
Mar 22 10:30:00.033 *apfMsConnTask_5 WLC/AP is sending an Association Response to the client with status code 0 = Successful association
Mar 22 10:30:03.082 *dtlArpTask Client has entered RUN state
Mar 22 10:30:03.083 *dtlArpTask Received DHCP ACK, assigning IP Address 172.29.139.45
Connection attempt #3
Mar 22 10:30:27.508 *apfMsConnTask_5 Client made new Association to AP/BSSID BSSID c4:0a:cb:24:c4:61 AP 1126-1stFloor01-LWAP
Mar 22 10:30:27.508 *apfMsConnTask_5 Client expiration timer code set for 1 seconds. The reason: Client deleted due to wlan change (fast SSID is disabled)
Mar 22 10:30:28.318 *apfReceiveTask Client session has timed out
Mar 22 10:30:28.318 *apfReceiveTask Client has been deauthenticated
Connection attempt #4
Mar 22 10:30:41.625 *apfMsConnTask_5 Client made new Association to AP/BSSID BSSID c4:0a:cb:24:c4:31 AP 1126-1stFloor01-LWAP
Mar 22 10:30:41.627 *apfMsConnTask_5 Client has entered DHCP Required state
Mar 22 10:30:41.627 *apfMsConnTask_5 Client has successfully cleared AP association phase
Mar 22 10:30:41.627 *apfMsConnTask_5 Client is entering PSK Dot1x or WEP authentication phase
Mar 22 10:30:41.627 *apfMsConnTask_5 Client expiration timer code set for 1800 seconds. The reason: Client is scheduled for session timeout deletion (wlan with webauth)
Mar 22 10:30:41.628 *apfMsConnTask_5 WLC/AP is sending an Association Response to the client with status code 0 = Successful association
Mar 22 10:30:45.574 *dtlArpTask Client has entered RUN state
Mar 22 10:30:45.575 *dtlArpTask Received DHCP ACK, assigning IP Address 172.29.139.45
Connection attempt #5
Mar 22 10:37:24.632 *apfMsConnTask_5 Client made new Association to AP/BSSID BSSID c4:0a:cb:24:c4:61 AP 1126-1stFloor01-LWAP
Mar 22 10:37:24.633 *apfMsConnTask_5 Client expiration timer code set for 1 seconds. The reason: Client deleted due to wlan change (fast SSID is disabled)
Mar 22 10:37:25.518 *apfReceiveTask Client session has timed out
Mar 22 10:37:25.518 *apfReceiveTask Client has been deauthenticated
Connection attempt #6
Mar 22 10:37:38.815 *apfMsConnTask_5 Client made new Association to AP/BSSID BSSID c4:0a:cb:24:c4:61 AP 1126-1stFloor01-LWAP
Mar 22 10:37:38.816 *apfMsConnTask_5 WLC recognizes that the client is 802.11r-capable
Mar 22 10:37:38.816 *apfMsConnTask_5 The WLC/AP has found from client association request Information Element that claims PMKID Caching support
Mar 22 10:37:38.816 *apfMsConnTask_5 WLC/AP is sending an Association Response to the client with status code 43 = Invalid AKMP
Mar 22 10:37:38.817 *apfMsConnTask_5 Client expiration timer code set for 3 seconds. The reason: Association processing failure, before reaching max error count for client
Connection attempt #7
Mar 22 10:37:38.846 *apfMsConnTask_1 Client made new Association to AP/BSSID BSSID c4:0a:cb:2c:10:9e AP 1126-1stFloor03-LWAP
Mar 22 10:37:38.848 *apfMsConnTask_1 WLC recognizes that the client is 802.11r-capable
Mar 22 10:37:38.848 *apfMsConnTask_1 The WLC/AP has found from client association request Information Element that claims PMKID Caching support
Mar 22 10:37:38.848 *apfMsConnTask_1 WLC/AP is sending an Association Response to the client with status code 43 = Invalid AKMP
Mar 22 10:37:38.848 *apfMsConnTask_1 Client expiration timer code set for 3 seconds. The reason: Association processing failure, before reaching max error count for client
Connection attempt #8
Mar 22 10:37:41.405 *apfMsConnTask_5 Client made new Association to AP/BSSID BSSID c4:0a:cb:24:c4:61 AP 1126-1stFloor01-LWAP
Mar 22 10:37:41.406 *apfMsConnTask_5 WLC recognizes that the client is 802.11r-capable
Mar 22 10:37:41.406 *apfMsConnTask_5 The WLC/AP has found from client association request Information Element that claims PMKID Caching support
Mar 22 10:37:41.406 *apfMsConnTask_5 WLC/AP is sending an Association Response to the client with status code 43 = Invalid AKMP
Mar 22 10:37:41.407 *apfMsConnTask_5 Client expiration timer code set for 3 seconds. The reason: Association processing failure, before reaching max error count for client
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
