Unable to copy and replace AP using prime Error COMMON-1
JosephPhilip1
We had a bad AP (CAP3602I) and we replaced it.While trying to copy and replace the AP using prime it shows some error like COMMON-1: Some unexpected internal error has occurred. If the problem persists please report to the Tech Support. What may be the issue ?
AFROJ AHMAD
Looks like there is already an entry in the db. Can you search for 'UnAssociated entries' as below & delete the entry ?
Also look under "look under Configure --> Access points" page for that  entry/ethernet mac & delete it ?
After doing above try to add it again.
Thanks-
Afroz
**Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
