Unable to join APs to controller
adminadmin7605
Visitor
Hi all,
i have a WLC AIR-CT3504-K9, firmware 8.5.131.0. I need to join 4 APs AIR-AP1832I-E-K9. Iv'e tried directly connected on WLC, on a POE switch with only one network range, nothing work. LEDs are blinking on AP (red/green/amber). Country code i set to Fr.
does somenone have any idea ?
thanks,
Make sure AP is getting teh IP address from DHCP else it will not join.
Dont forget to rate helpful posts
10 Replies 10
HaifengLi
Have you tried ping? wlc --> ap WLC: show interface summ show inter deta mana AP: show ip int bri SW: sh run int gix/x
I can see AP  in "wireless> direct APs" when directly connected on WLC ports but with no IP.
Leo Laohoo
Post the complete output to the following commands:
1. WLC: sh sysinfo;
2. WLC: sh time;
3. AP: sh version; and
4. AP: sh ip interface brief
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.131.0
RTOS Version..................................... 8.5.131.0
Bootloader Version............................... 8.5.103.0
Emergency Image Version.......................... 8.5.103.0
OUI File Last Update Time........................ N/A
Build Type....................................... DATA + WPS
System Name...................................... cisco-cont-Arth
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2427
Redundancy Mode.................................. Disabled
IP Address....................................... 172.16.102.1
IPv6 Address..................................... ::
Last Reset....................................... Cold reset due to PLL_DC_OK
System Up Time................................... 0 days 22 hrs 49 mins 42 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
--More-- or (q)uit
System Stats Normal Interval..................... 180
Configured Country............................... FR - France
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... -10 to 80 C
Internal Temperature............................. +56 C
Mgig Temp Alarm Limits........................... -10 to 78 C
Mgig Temperature................................. +44 C
External Temp Alarm Limits....................... -10 to 71 C
External Temperature............................. +37 C
Fan Status....................................... OK
Fan Speed Mode................................... Disable
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ CC:70:ED:15:A8:70
Maximum number of APs supported.................. 150
System Nas-Id....................................
--More-- or (q)uit
WLC MIC Certificate Types........................ SHA1/SHA2
Licensing Type................................... RTU
Time............................................. Thu Aug 29 14:01:11 2019
Timezone delta................................... 0:0
Timezone location................................ (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
NTP Servers
NTP Version.................................. 3
NTP Polling Interval......................... 86400
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 172.16.100.110 In Sync AUTH DISABLED
i cannot enter on APs commands, on console port, boot sequence always run on "addrconf(netdev_up) link is not ready" to bring an IP.
thanks,
Check if AP is getting IP or not via console access.
Also paste the complete bootup process from AP console.
Reboot the AP and paste the complete logs from console.
U-Boot 2012.07 (btldr release 31) (Mar 15 2017 - 15:00:35)
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM: 1 GiB
NAND (ONFI): Detected MICRON MT29F2G08ABBEAH4 [256 MiB]
SF: Detected Macronix MX25U3235F [4 MiB]
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[1:0], write_counter=3
PCI0 Link Intialized
PCI1 Link Intialized
Net:
PHY ID = 0x4dd074, eth0 found AR8033 PHY
PHY ID = 0x4dd074, eth1 found AR8033 PHY
Valid I2C chip addresses: 51 52
AP 1832 . detected...
Power Type: 802.3at POE detected...
Signature returns 0
BL signing verification success, continue to run...
Auto boot mode, use bootipq directly
Hit ESC key to stop autoboot: 0
Specified BOOT: part1
Booting from part1
Read 1024 bytes from volume part1 to 45000000
Read 23462495 bytes from volume part1 to 45000000
UBI: fixable bit-flip detected at PEB 161
UBI: schedule PEB 161 for scrubbing
Signature returns 0
Image signing verification success, continue to run...
Using machid 0x1260 from environment
Starting image ...
[01/01/1970 00:00:00.0000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
[01/01/1970 00:00:00.0000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[01/01/1970 00:00:00.0000] Machine: Cisco Systems 11ac Wave2 Wifi Access Point
[01/01/1970 00:00:00.0000] Memory policy: ECC disabled, Data cache writealloc
[01/01/1970 00:00:00.0000] Kernel command line: ubi.mtd=0 crashkernel=30M@1280M console=ttyHSL1,9600n8 activepart=part1 activeboot=0 wdgtriggered=0
[01/01/1970 00:00:00.1500] CPU1: Booted secondary processor
[01/01/1970 00:00:00.2200]
[01/01/1970 00:00:00.2200] +++ hydra_ap_gpio_value =2
[01/01/1970 00:00:08.7174] [sched_delayed] sched: RT throttling activated
[01/01/1970 00:00:18.7943] ACPU PVS: 1
[01/01/1970 00:00:19.8139] buginf tty flushing thread started, ttyport=ef577290
[01/01/1970 00:00:24.4125] msm_hsusb_host msm_hsusb_host: unable to find transceiver
[*01/01/1970 00:00:24.6524] buginf() enabled.
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
[*01/01/1970 00:00:24.6624] Made it into bootsh: Jun 4 2018 23:03:02
[*01/01/1970 00:00:24.6624] bootsh build T-5a1977b5600aa94dd31adcabae872ed6700b2ea1-g5a1977b5-vipendya
init started: BusyBox v1.23.2 (2018-06-04 22:46:06 PDT)
[*01/01/1970 00:00:27.6915] GCM-128 POST passed
[*01/01/1970 00:00:27.6915] GCM-256 POST passed
[*01/01/1970 00:00:27.9514] Active version: 8.3.143.0
[*01/01/1970 00:00:27.9514] Backup version: 0.0.0.0
[*01/01/1970 00:00:28.1713] AP1832I
Jan 1 00:00:28 FIPS[787]: *** shell: FIPS Mode = disabled ***
User Access Verification
Username: [*01/01/1970 00:00:28.2713] nss_driver - Turbo Support 1
[*01/01/1970 00:00:28.2713] Supported Frequencies - 110Mhz 550Mhz 733Mhz
[*01/01/1970 00:00:28.7412] Current value of FACTORY_RESET=0
[*01/26/2019 23:59:59.0099] Last reload time: Jan 26 23:59:59 2019
[*01/26/2019 23:59:59.0000] Setting system time Sat Jan 26 23:59:59 UTC 2019
[*01/26/2019 23:59:59.0599]
[*01/26/2019 23:59:59.0599] === 5G radio domain is 12, COPY 5G BDF files from ETSI_BDF folder ===
[*01/26/2019 23:59:59.1499] device wired0 entered promiscuous mode
[*01/26/2019 23:59:59.5298] stile module dp init successfully
[*01/26/2019 23:59:59.5298] NBAR Label:BLD_MCP_DEV_LATEST_20150424_123021 NBAR VERSION:module build date: Oct 4 2017 at 08:58:38
[*01/27/2019 00:00:00.1396] miibus get eec90c00!
[*01/27/2019 00:00:00.1696]
[*01/27/2019 00:00:00.1696] boot 4 build T-5a1977b5600aa94dd31adcabae872ed6700b2ea1-g5a1977b5-vipendya board corsica mac DC:F7:19:68:16:B0
[*01/27/2019 00:00:00.1796] Module: mbedtls .text=0xbf000000 data=0xbf007e18 bss=0xbf008070
[*01/27/2019 00:00:00.1796] Module: aptrace .text=0xbf00c000 data=0xbf0141dc bss=0xbf0145e0
[*01/27/2019 00:00:00.1796] Module: qca_nss_gmac .text=0xbf01b000 data=0xbf021b7c bss=0xbf02203c
[*01/27/2019 00:00:00.1796] Module: qca_nss_drv .text=0xbf02b000 data=0xbf042a40 bss=0xbf0437f0
[*01/27/2019 00:00:00.1796] Module: qca_nss_capwapmgr .text=0xbf05f000 data=0xbf062b78 bss=0xbf062cc8
[*01/27/2019 00:00:00.1796] Module: nssmgrctl .text=0xbf068000 data=0xbf069728 bss=0xbf069a4c
[*01/27/2019 00:00:00.1796] Module: proclikefs .text=0xbf06f000 data= bss=0xbf06fb40
[*01/27/2019 00:00:00.1796] Module: stile_lm_ft .text= data= bss=
[*01/27/2019 00:00:00.1796] Module: stile_lm_dp .text= data= bss=
[*01/27/2019 00:00:00.1796] Module: bonding .text=0xbf976000 data=0xbf98763c bss=0xbf987a68
[*01/27/2019 00:00:00.1796] Module: ipv6 .text=0xbf994000 data=0xbf9c4840 bss=0xbf9c60ec
[*01/27/2019 00:00:00.1796] Module: lowmemorykiller .text=0xbf9df000 data=0xbf9df2c0 bss=0xbf9df44c
[*01/27/2019 00:00:00.1796] Module: qca_nss_profile_drv .text=0xbf9e3000 data=0xbf9e4324 bss=0xbf9e4498
[*01/27/2019 00:00:00.1796] Module: ssdk_reg .text=0xbf9e9000 data= bss=0xbf9e9838
[*01/27/2019 00:00:00.6095] Last reload reason : 0: unknown
[*01/27/2019 00:00:02.2590]
[*01/27/2019 00:00:02.2590] __ol_ath_attach() Allocated scn c4040480
[*01/27/2019 00:00:02.2690] Chip id: 0x9, chip version: 0x1000000
[*01/27/2019 00:00:02.2690] Target Version is 1000000
[*01/27/2019 00:00:02.2690] Flash Download Address c0000
[*01/27/2019 00:00:02.2690] ol_transfer_bin_file: flash data file defined
[*01/27/2019 00:00:02.2690] Cal location [0]: 00000000
[*01/27/2019 00:00:02.2690] Wifi0 NAND FLASH Select OFFSET 0x1000
[*01/27/2019 00:00:02.2890] qc98xx_verify_checksum: flash checksum passed: 0x2df3
[*01/27/2019 00:00:02.2890] ol_transfer_bin_file 4092: Download Flash data len 12064
[*01/27/2019 00:00:02.3090]
[*01/27/2019 00:00:02.3090] Board data initialized
[*01/27/2019 00:00:02.3589] ol_ath_download_firmware :First OTP download and Execute is good address:0xa000 return param 4660
[*01/27/2019 00:00:02.3589] ol_ath_download_firmware:##Board Id 8 , CHIP Id 1
[*01/27/2019 00:00:02.3589] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_v2_008.bin
[*01/27/2019 00:00:02.4389]
[*01/27/2019 00:00:02.4389] [Flash] : Ignore Module param
[*01/27/2019 00:00:02.4389] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*01/27/2019 00:00:02.4589] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*01/27/2019 00:00:03.5586] HTC Rx: insufficient length, got:4 expected =8
[*01/27/2019 00:00:03.5586] Startup Mode-0 set
[*01/27/2019 00:00:03.5586] HTC Service:0x0300 ep:1 TX flow control disabled
[*01/27/2019 00:00:03.5586] HTC Service:0x0100 ep:2 TX flow control disabled
[*01/27/2019 00:00:03.5586] Firmware_Build_Number:5
[*01/27/2019 00:00:03.5586] num_rf_chain:0x00000003 ht_cap_info:0x0000185b vht_cap_info:0x339a79b2 vht_supp_mcs:0x0000ffea
[*01/27/2019 00:00:03.5586] RES CFG Support wmi_service_bitmap 9778
[*01/27/2019 00:00:03.5586] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 10 to TGT
[*01/27/2019 00:00:03.5586] Mesh Supported
[*01/27/2019 00:00:03.6385] wmi_ready_event_rx: WMI UNIFIED READY event
[*01/27/2019 00:00:03.6385] ACS not enabled
[*01/27/2019 00:00:03.6485] ol_ath_thermal_mitigation_attach: --
[*01/27/2019 00:00:03.6485] __ol_ath_attach() Allocated scn ebfc0480
[*01/27/2019 00:00:03.6585] Chip id: 0x9, chip version: 0x1000000
[*01/27/2019 00:00:03.6585] Target Version is 1000000
[*01/27/2019 00:00:03.6585] Flash Download Address c0000
[*01/27/2019 00:00:03.6585] ol_transfer_bin_file: flash data file defined
[*01/27/2019 00:00:03.6585] Cal location [1]: 00004000
[*01/27/2019 00:00:03.6585] wifi1 NAND FLASH Select OFFSET 0x5000
[*01/27/2019 00:00:03.6785] qc98xx_verify_checksum: flash checksum passed: 0x40b9
[*01/27/2019 00:00:03.6785] ol_transfer_bin_file 4092: Download Flash data len 12064
[*01/27/2019 00:00:03.6985]
[*01/27/2019 00:00:03.6985] Board data initialized
[*01/27/2019 00:00:03.7485] ol_ath_download_firmware :First OTP download and Execute is good address:0x9c00 return param 4660
[*01/27/2019 00:00:03.7485] ol_ath_download_firmware:##Board Id 7 , CHIP Id 1
[*01/27/2019 00:00:03.7485] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS239_negative_pwr_offset_5G_v2_007.bin
[*01/27/2019 00:00:03.8185]
[*01/27/2019 00:00:03.8185] [Flash] : Ignore Module param
[*01/27/2019 00:00:03.8185] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*01/27/2019 00:00:03.8385] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*01/27/2019 00:00:04.5583] FWLOG: [33920] WAL_DBGID_AST_DEL_WDS_ENTRY ( 0xdeadc0de, 0xea, 0x32 )
[*01/27/2019 00:00:04.5583] FWLOG: [33992] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 )
[*01/27/2019 00:00:04.5583] FWLOG: [33992] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*01/27/2019 00:00:04.5583] FWLOG: [33992] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*01/27/2019 00:00:04.5583] FWLOG: [33992] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*01/27/2019 00:00:04.9381] HTC Rx: insufficient length, got:4 expected =8
[*01/27/2019 00:00:04.9381] Startup Mode-0 set
[*01/27/2019 00:00:04.9381] HTC Service:0x0300 ep:1 TX flow control disabled
[*01/27/2019 00:00:04.9481] HTC Service:0x0100 ep:2 TX flow control disabled
[*01/27/2019 00:00:04.9481] Firmware_Build_Number:5
[*01/27/2019 00:00:04.9481] num_rf_chain:0x00000004 ht_cap_info:0x0000185b vht_cap_info:0x339b79b2 vht_supp_mcs:0x0000ffea
[*01/27/2019 00:00:04.9481] RES CFG Support wmi_service_bitmap 9778
[*01/27/2019 00:00:04.9481] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 10 to TGT
[*01/27/2019 00:00:04.9481] Mesh Supported
[*01/27/2019 00:00:05.0181] wmi_ready_event_rx: WMI UNIFIED READY event
[*01/27/2019 00:00:05.0181] acfg_attach: Offload using existing sock ec727000
[*01/27/2019 00:00:05.0181] ACS not enabled
[*01/27/2019 00:00:05.0281] ol_ath_thermal_mitigation_attach: --
[*01/27/2019 00:00:05.0381] pktlog_init: Initializing Pktlog for AR900B, pktlog_hdr_size = 16
[*01/27/2019 00:00:05.9378] FWLOG: [35293] WAL_DBGID_AST_DEL_WDS_ENTRY ( 0xdeadc0de, 0xea, 0x32 )
[*01/27/2019 00:00:05.9378] FWLOG: [35363] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 )
[*01/27/2019 00:00:05.9378] FWLOG: [35363] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*01/27/2019 00:00:05.9378] FWLOG: [35363] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*01/27/2019 00:00:05.9378] FWLOG: [35363] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*01/27/2019 00:00:05.9378] FWLOG: [35371] UNKNOWN 22:55 ( 0x3a, 0x10, 0x0, 0x10, 0x0 )
[*01/27/2019 00:00:06.8375] pid 1617's current affinity mask: 3
[*01/27/2019 00:00:06.8375] pid 1617's new affinity mask: 1
[*01/27/2019 00:00:08.3671] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg40000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000
[*01/27/2019 00:00:09.4867]
[*01/27/2019 00:00:09.4867] Click sched monitor: schedulers = 1
[*01/27/2019 00:00:10.4765] wired0: 1000 Mbps Full Duplex
[*01/27/2019 00:00:22.9825] Loading sha2...
[*01/27/2019 00:00:22.9825] Dumpping sha1...
[*01/27/2019 00:00:24.9319] Loading MIC cert and key
[*01/27/2019 00:00:24.9319] Dumpping sha2...
[*01/27/2019 00:00:26.7614] Loading MIC cert and key
[*01/27/2019 00:00:27.1512] Generating key, this may take a while...
[*01/27/2019 00:00:29.6205] Public key portion is:
[*01/27/2019 00:00:29.6205] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCarHzguCgA0bzFJi7gNDglFm5GlnXALPr7E7bv85FbDwGP8Xz3bVqgY51CUwy2943s97/WLJ6fGx+21SFebV/eDznu1SMgo3fnkFZkr3El8aKWYDlqNepcp5lQYnJcK4jJV2ySe9Dssq5U4IvmPj37J2zbp1IWL8/ej2zL956s4JtrMCrCJ9ZDn4kQqp/JWswSkpNxGYgFc1FRij4N0awHuOH4ASKhkyhWRLQy/tmjflJ0x9Oo/ZMBVOO0bE7sJ3BONdaF8Ts1tN4iBG8Xn7BVQC87SJYFgngp9IZP3qcOHve8jGH1Tm4l/O20PiM3BbGaKU8Zz6TunjTYG5XmIcUJ root@mDCF7196816B0
[*01/27/2019 00:00:29.6205] Fingerprint: md5 1e:32:63:44:8c:9a:67:ce:41:4f:70:be:c4:e9:f9:8b
[*01/27/2019 00:00:29.6805] pid 2995's current affinity mask: 3
[*01/27/2019 00:00:29.6805] pid 2995's new affinity mask: 1
[*01/27/2019 00:00:30.1403] gzip -dc /etc/wcp.usermodule.template.gz | sed -e 's/__TX_POWER_2G_FILE__/\/radio_fw\/S2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio_fw\/S5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM_POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/1/g' -e 's/__DOMAIN_5G__/12/g' -e 's/__PRODUCT_ID__/AIR-AP1832I-E-K9/g' -e 's/__AP_TYPE__/58/g' -e 's/__WIRELESS_MAC__/DC:F7:19:68:C1:20/g' -e 's/__WIRED_MAC__/DC:F7:19:68:16:B0/g' -e 's/__WIRED1_MAC__/DC:F7:19:68:16:B0/g' | DMALLOC_OPTIONS=debug=0x03,inter=1000,log=/tmp/wcp.dmalloc.log,limit=40000000 wcpd &
[*01/27/2019 00:00:30.6302] Password for 'Cisco' changed
[*01/27/2019 00:00:31.6998] DOT11_DRV[0]: Init Radio0
[*01/27/2019 00:00:31.7198] DOT11_DRV[0]: Stop Radio0
[*01/27/2019 00:00:31.7298] DOT11_DRV[0]: set_channel Channel set to 6
[*01/27/2019 00:00:31.7298] DOT11_DRV[1]: Init Radio1
[*01/27/2019 00:00:31.7498] DOT11_DRV[1]: Stop Radio1
[*01/27/2019 00:00:31.7598] DOT11_DRV[1]: set_channel Channel set to 36
[*01/27/2019 00:00:32.6895] DOT11_DRV[0]: set_channel Channel set to 1
[*01/27/2019 00:00:32.6995] DOT11_DRV[0]: Channel set to 1, width 20
[*01/27/2019 00:00:32.7195] DOT11_DRV[1]: set_channel Channel set to 36
[*01/27/2019 00:00:32.7195] DOT11_DRV[1]: Channel set to 36, width 20
[*01/27/2019 00:00:36.7283] Waiting for uplink IPv4/IPv6 configuration
[*01/27/2019 00:00:41.7267] Waiting for uplink IPv4/IPv6 configuration
[*01/27/2019 00:00:46.7251] Waiting for uplink IPv4/IPv6 configuration
[*01/27/2019 00:00:47.7248] Resetting wired0, ifconfig down up
[*01/27/2019 00:00:49.7442] ADDRCONF(NETDEV_UP): wired0: link is not ready
[*01/27/2019 00:00:50.4740] ADDRCONF(NETDEV_CHANGE): wired0: link becomes ready
[*01/27/2019 00:00:50.4840] wired0: 1000 Mbps Full Duplex
[*01/27/2019 00:00:53.7529] Waiting for uplink IPv4/IPv6 configuration
[*01/27/2019 00:00:58.7614] Waiting for uplink IPv4/IPv6 configuration
[*01/27/2019 00:01:03.7598] Waiting for uplink IPv4/IPv6 configuration
[*01/27/2019 00:01:04.7595] Resetting wired0, ifconfig down up
[*01/27/2019 00:01:06.7789] ADDRCONF(NETDEV_UP): wired0: link is not ready
[*01/27/2019 00:01:07.4886] ADDRCONF(NETDEV_CHANGE): wired0: link becomes ready
[*01/27/2019 00:01:07.4986] wired0: 1000 Mbps Full Duplex
[*01/27/2019 00:01:10.7776] Waiting for uplink IPv4/IPv6 configuration
I'd recommend upgrading the firmware of the controller. 8.5.131.0 is very, very buggy.
