Distance between two Wireless Access point 1562D
abdulkarim041
Level 5
Level 5
I want to know How I can get/calculate  the distance between two Cisco 1562D access points?
BR
Abdul Karim
Sandeep Choudhary
HI,
here is a bridge calculator to give you some idea.
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-350-series/18860-outdoor-br-utility-calc.html
Dont forget to arte helpful posts
pieterh
I think you mean to determine the "cell-size" of e WAP?
that depends what kind of antenna you use, and what environment (open space or office, etc.)
look at the Enterprise Mobility 8.x Design Guide (s)  and in this document look at the section about wifi-cell-size
