Unable to register 5520 WLC with Cisco Smart Licensing
akram.root
Level 4
Level 4
Hello ALL,
I have configured my Cisco 5520 running 8.10.122.0 to use Smart Licensing.  Cisco Licensing has created the license for the 5520 but when I try to register the 5520 it always fails.  I am using the correct token id from Smart licensing portal but I get the following when I try to register.
Smart Licensing is ENABLED
Utility:
  Status: DISABLED
Data Privacy:
  Sending Hostname: yes
    Callhome hostname privacy: DISABLED
    Smart Licensing hostname privacy: DISABLED
  Version privacy: DISABLED
Transport:
  Type: Callhome
Registration:
  Status: REGISTERING - REGISTRATION IN PROGRESS
  Export-Controlled Functionality: NOT ALLOWED
  Initial Registration: FAILED on Jun 24 2020 18:01:48 BST
    Failure reason: Fail to send out Call Home HTTP message.
  Next Registration Attempt: Jun 24 2020 18:18:59 BST
License Authorization:
  Status: No Licenses in Use
Export Authorization Key:
  Features Authorized:
    <none>
Could you help me please !
Best regards
Hello ,
It's worked after put this commande : config call-home http-proxy ipaddr 0.0.0.0
and put the name of controller in the page call home configuration
Best regards
Sandeep Choudhary
Can you try this command:
Info: This command is used to reset the http proxy settings
Dont forget to rate helpful posts
thank you for your reply , i used it , but the problem persist
Best regards
Hello ,
Best regards
Go through the guide again and put the correct DNS server IP (Enter the DNS server IP address that will be used to resolve the Smart License and Smart call-home URLs in the call-home profile) and token ID.
https://content.cisco.com/chapter.sjs?uri=%2Fsearchable%2Fchapter%2Fc%2Fen%2Fus%2Ftd%2Fdocs%2Fwireless%2Ftechnology%2Fmesh%2F8-2%2Fb_Smart_Licensing_Deployment_Guide.html.xml&query=To%20activate%20Smart%20Licensing%20on%20the%20WLC
