02-21-2011 03:29 AM - edited 07-03-2021 07:51 PM
Hello Experts,
I have number of 1130ag access points in our network. The problem i am facing is that when I tried to set the speed on the dot11Radio 0 and 1 interface it doesn't appear
This is the command I am using:
interface dot11Radio 0
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
Please can someone help me.
02-21-2011 05:06 AM
The configurations that you are entering.. that is..
is the Default config for 802.11G and by nature the default configurationas will not appear in the running config.. another example is.. By default Aironet Extentions are enabled on the AP runing config, and in the Show run you will see that.. but when you isue the command no dot11 extension aironet thne this command wil show up!! please make the change and then you will be able to see.. here is the link as well which can be used to set the values..
lemme know if this answered your question
Surendra
02-21-2011 11:35 AM
Hi Surendra,
Thank you for such a wonderful clarification. However, I would like to ask what speed would you recommend to set on the interface to get reliability and stability.
02-21-2011 05:18 PM
It depends on your requirements.. I prefer leaving it to default!!
Surendra
02-21-2011 10:34 PM
Hi Surendra,
My environment is such like that
a. WAP configured with 3 ssid's
b.WDS configured
c.Each floor has around 5 access points.
d. Clients associate with laptop wireless device or any other 3rd party device
Please any suggestion.
02-21-2011 10:42 PM
Hi Sam,
the BEST RANGE will increase the range and decreases the throughput
the BEST THROUGHPUT will increase the throughput but decreases the range.
The DEFAULT will be in between the above both and works great!! i go for Default and make sure we have the seamless roaming between the APs.
Surendra
02-21-2011 10:59 PM
Hi Surend,
Thank you for your quick reply.
I've an last question here. at particular locations in our reuirement some clients when they associate with AP and works on application ( hospital mangement system) it seems to be very slow. For diagnosis, i used a ping tool the replies are not stable and sometimes I recieve request timed out.
Even though the client is very near to the AP. Pleas can you suggest. I really appreciate your support.
Thank You
Samir
02-21-2011 11:03 PM
Ok, the client is near to the AP but are they able to see the SSID?? whats does the log say on the AP when the issue happens??
Surendra
02-21-2011 11:09 PM
Yes, the client can see the SSID with with excellent signal. However, i do not see any logs which indicates the issue.
When I visited the client, they are getting speed of 11.0mbps or sometime 48.0 mbps...no stability
02-21-2011 11:13 PM
This happens when we have RF interference issue as well.. run the carrier busy test and see whats the interference percentage that we see on the Radio channels.
Surendra
02-21-2011 11:37 PM
Hi Surend,
Hers is the result of sh dot11 carrier busy
Frequency Carrier Busy %
2412 0
2417 0
2422 0
2427 0
2432 0
2437 0
2442 0
2447 0
2452 4
2457 6
2462 5
2467 3
2472 2
Thanks for your help.
02-22-2011 12:10 AM
ha ha ha strange!! are you sure that from the same AP we are getting 11 at one time and 48 the next moment??
Surendra
02-22-2011 12:13 AM
Yes, I am sure its from the same AP. Even I am confused..
02-22-2011 12:22 AM
Ok.. shut down thew radio of the other AP and see whats the signal strength and the speed we are able to see..
Surendra
02-22-2011 09:18 AM
Are you sure you are not running into any interference which is making the the radios change modulation?
