Unable to upgrade Cisco Wireless Controller 2504
manunited332
i am trying to upgrade cisco wireless controller AIR-CT2504-K9 from version 8.3.140.0 to 8.5.171 , I've uploaded the image via gui to the wlc,
(Cisco Controller) >show boot
Primary Boot Image............................... 8.5.171.0 (default)
Backup Boot Image................................ 8.3.140.0 (active)
then i run the command "config ap image predownload priamry all" on wlc but its keep failing
Predownload Predownload Flexconnect
AP Name Primary Image Backup Image Status Version Next Retry Time Retry Count Predownload
wap002 8.3.140.0 0.0.0.0 Failed 8.5.171.0 18:02:06 64
wap003 8.3.140.0 0.0.0.0 Failed 8.5.171.0 18:37:50 64
AIR-CAP2602I-A-K9
any advise is highly appreciated, there is no redundancy for this wlc
Many Thanks
                                                 >...and now lost access to APs,
  - If APs are on POE through switchport you may recover them by shutting and un-shutting the ports they are connected to , because that implies a power cycle ,
 M.
9 Replies 9
balaji.bandi
what AP Models you have, have you checked the compatability matrix :
what AP models WAP002 and 003 ?
check the release notes :
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85mr7.html
BB
manunited332
AP Model is AIR-CAP2602I-A-K9 and as per document they are compatible.
marce1000
 - Connect to one of the APs and issue the command show logging , you may get additional info's .
 M.
manunited332
I've rebooted WLC and now lost access to APs, unable to raise tac case as they have past their end of support date.
I still have access to WLC
 M.
gadgeonsubin
Have you tried upgrading via CLI?
manunited332
As Marce1000 suggested, I bounced the APs from the switch and they came back up with the new image, life is good again.
Thanks all for your help.
Rich R
You should NOT be using 8.5.171.0!
The only version of 8.5 you should use is 8.5.182.7 - link below.
Refer to field notices below.
Leo Laohoo
@Rich R is correct.
The APs will not be able to complete the automated download due to FN - 72524 - During Software Upgrade/Downgrade, Cisco IOS APs Might Remain in Downloading State After December 4, 2022 Due to Certificate Expiration.
Either upgrade to the fixed version or perform a manual upgrade of the selected APs.
