Unsecured Wireless
one3cap12
Community Member
Does anybody know how I can get 2 SSID's on a Aironet 1100 AP and have 1 secured and the other non-secured......open for anybody to use?
andrew.prince
Level 11
Level 11
Michael,
Is the AP - LWAPP enabled or IOS? you can tell via the console.
matthogue
Level 2
Level 2
You may want to see if a vlan is necessary on your network, specifically if you are running VoIP.
With a 1200 series Ap, all you have to do is configure the ssid as authentication open on the unsecured, and add the security to the other ssid.
This is what I have ...
dot11 ssid secured
authentication open eap eap_methods
authentication network-eap eap_methods
accounting acct_methods
dot11 ssid unsecured
authentication open
infrastructure-ssid optional
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode wep mandatory
broadcast-key change 10800
ssid secured
ssid unsecured
Hope this helps.
I have done this for AP1200s, but not 1100s.
