Unspecified session lost for hidden ssid
CCC3
Level 5
Level 5
I'm using wlan as hidden for WLC5520.
I'm simply using it as a psk,
It is said that the terminal ends the session unspecified and asks for psk again.
session timeout or idle timeout is unchecked.
The device is intel ax211.
Is this a hidden problem?
Is it a problem with the terminal's wireless LAN card setting?
7 Replies 7
Rich R
1. What software version are you using on the 5520?
It should be on latest version 8.10.196.0.
2. What driver version are you using? Make sure it's up to date:
https://www.intel.com/content/www/us/en/download/19351/intel-wireless-wi-fi-drivers-for-windows-10-and-windows-11.html
3. Have you enabled debug for the client MAC address and run the results through the Debug Analyzer (link below)?
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
Saikat Nandy
Can you share more info about the problem statement please. Like users are getting disconnected intermittently or what exactly the pattern/behaviour is?
Since it is aireos, disabling session timeout means max value and unchecked idle timeout means global idle timeout is working.
WLC : 5520(8.10.183.0)
AP : 9115, 2802, 2702..
WLAN : PSK, no Broadcast SSID
CLIENT : intel AX211 160MHz
It's the same as above
The issue is that the client accesses and uses the WLAN and asks for the PSK KEY value again as if the session is released.
The session timeout and idle timeout that you mentioned are set to the same as the capture
Where are the global settings for idle timeout?
Global idle timeout is available under Controller >> General tab.
Can you take a 'debug client <mac addr>' of the user reproducing the issue and share please.
It is difficult to collect debug right now.
Is there any issue regarding session timeout and idle timeout?
There is nothing as such...without debug client it's hard to speculate what's going on to be honest.
@CCC3
Upgrade to 8.10.196.0 as per TAC recommended releases.  There are literally hundreds of bug fixes since 8.10.183.0
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn810mr9.html#resolved-caveats
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn810mr10.html#fixed-issues
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn810mr11.html#fixed-issues
Update to latest Intel driver (link provided in previous reply)
It's really not worth trying to work out what the problem is until you have ensured that the client and WLC software is up to date.  The earlier Intel drivers had severe bugs.
