Upgrade autonomous to lightweight using tftp
I'm have new autonomous 1242 AP without any configuration. Can I convert it to lightweight using tftp? Which image should I use.
The current version is 12.3(7)JA5.
Many thanks in advance.
Rgds,
Fauzan
Surendra BG
Hi Mohd,
yes u can directly convert it to LWAPP image.. go for the latest LWAPP that we have for that product.. the below doc may help u as well!!
https://supportforums.cisco.com/docs/DOC-14960
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
Surendra BG
Hi Mohd,
Surendra
Surendra BG
Thanks surendra, will try that tomorrow.
