09-02-2009 07:22 AM - edited 07-03-2021 06:00 PM
we added wism module in 6509 switch, but
wcs cound not add wism(wireless controller).
currently, wcs version is 4.2.176.0
wism version is 6.0.182.0
do you know why?
No response from device, check SNMP communities, version or network for issues.
error message
09-02-2009 07:43 AM
check the routing between WCS & the wisms, as wisms will have a unique subnet as part of the configuration with the 6500
09-02-2009 07:45 AM
Also, you should upgrade WCS to a later version. The 6.x WCS is a lot better in terms of navigation & performance
09-02-2009 10:00 AM
Hi FW,
Just to add a note here to the great tips from Eric (+5 points buddy :)
The WCS must be at an equal or higher version level than the WLC/WISM to be able to manage it.
Cheers!
Rob
09-14-2009 06:07 PM
To add some precision to Rob post:
Not only you need higher version of WCS, you ALSO need the release date of the WCS software must be AFTER the one for the controller.
The dates are posted next to the release notes:
http://www.cisco.com/en/US/products/ps6305/prod_release_notes_list.html
http://www.cisco.com/en/US/products/ps6366/prod_release_notes_list.html
