07-16-2018 07:01 AM - edited 07-05-2021 08:52 AM
I have a question regarding the 3802i Cisco Aironet.
Indeed, there is a usb port behind the AP and my question is the following one :
It's possible to upgrade the IOS of the 3802i Cisco Aironet thanks to a USB Key ?
Thanks in advance for your return.
Best regards.
Kevin M
Solved! Go to Solution.
07-16-2018 09:00 AM
07-16-2018 03:30 PM
07-16-2018 09:00 AM
07-16-2018 03:30 PM
07-17-2018 01:01 AM
Thanks for your answer guys :) !
I tested to upgrade the AP with a TFTP Server but it didn't work nonetheless i deactivated the Windows firewall and my antivirus :(.
Do you know another way to do it ?
Thanks in advance for your answer.
Best regards.
Kevin MELKA
07-17-2018 01:02 AM
07-17-2018 01:09 AM
I used TFTP64 server but it's not really user friendly :s.
Do you know another TFTP server solution which is great except TFTP64 and TFTP Solarwinds ?
To answer to your question, i used this documentation to do it :
If you have another one, it would be great :).
Thanks in advance.
Best regards.
Kevin M
07-17-2018 01:16 AM
TFTP64 & Solarwinds are de facto "standard" and recommended.
Can you try running TFTPd64 on a different machine?
The command "archive download-sw tftp://TFTP_IP_ADDRESS/filename.tar" is what should be used.
What error messages are you getting when you try the above command?
07-18-2018 07:39 AM
I tried to do the command but i have nothing.
What is the procedure to upgrade the IOS of a Cisco AP (in this case 3802i) ?
Thanks in advance for your help.
Best regards.
Kevin M
07-18-2018 05:30 PM
What IOS are you trying to upgrade? The CAPWAP image or Mobility Express image?
