Upgrade issue with 5508 controller
william.briere
Level 5
Level 5
I have a 5508 wireless controller running version 6.0.199.4 (the image installed when the device was shipped) and I am trying to install by tftp version 7.3.112.0
The issue is when using tftpd32 gets to 82% transfered then fails with the error "% Error: Code file transfer failed - Error while writing output file"
Any ideas? (Yes, I've rebooted my controller and re-downloaded the file)
2 Accepted Solutions
George Stefanick
You need to go 7.0 before you jump here are the release notes
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn73.html#wp976667
Good catch George!
You should always read the release notes so you know what's broke:). Like if you have 1142's you shouldn't use 7.4. If you have 3600's don't use 7.3:)
-Scott
7 Replies 7
Scott Fella
Try using 3CDeamon. That's what I use with no issues. Also verify the md5 when you download images. That could be the issue also.
-Scott
George Stefanick
I think you also need to jump to 7.0 code before going to 7.3 ..
George Stefanick
That was it... Never thought I'd need to look that closely at the release notes.
Thanks!
Good catch George!
-Scott
Thanks for the reply Scott. I have 2602's and went with 7.4
George Stefanick
If you can mark the question as answered it will help others find a fix quicker ..
Thanks and enjoy 7.3
