Upgrade path for WLC
Prasan Venky
Level 7
Level 7
Hello all,
We are planning to upgrade our controller 5508 from 7.0.116.0 to 7.1.91.0. Is this directly possible or i have to put some other image before directly upgrading it?
please provide link stating this.
KVS
Agreed. You will be fine there is no issues from 7.0.116.0 to 7.1.91.0. We had a customer who did it .. Not many folks go to 7.1.91.0.  It was added for 3600 ap support.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
7 Replies 7
George Stefanick
Here is the matrix
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
You should be good to go
Hello george,
I could find the below. But after 7.0.98.218, its not suggesting the later release(7.0.116.0) for direct upgrade...?
Table 1-1     Upgrade Path to Controller Software Release 7.1.91.0
Current Software Release
Upgrade Path to 7.1.91.0 Software
6.0.188.0 or later 6.0 release
You can upgrade directly to 7.1.91.0.
6.0.196.0 or later 6.0 release
7.0.98.0
7.0.98.218
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_1_91_0.html#wp784198
KVS
Leo Laohoo
Why don't you go directly to 7.4.100.X?
Because he likes his wireless network and the stability !
Then I'd stick with 7.0.240.X.  LOL
Scott Fella
I don't think v7.1 is available to download anymore as it was just an interim code.
-Scott
