Upgrade Prime Infra 1.4 to 2.0: is there no way other than fresh install
iantra123
Level 3
Level 3
We want to upgrade a Prime Infrastructure from 1.4 to 2.0.
Cisco document says that there is no upgrade path from Prime Infrastructure 1.4 to Prime Infrastructure 2.0.
So how to do if I want to upgrade from 1.4 to 2.0: I have to insert all configuration manually? :'(
Antra
Sandeep Choudhary
HI Antra,
There is no upgrade path from Prime Infrastructure 1.4 to Prime Infrastructure 2.0.
as per my knowledge you must start it from scratch.
Info:
Prime Infrastructure 1.4 is a separate software train parallel with Prime Infrastructure 1.3 and 2.0.
The next maintenance release for users of Prime Infrastructure 1.4 will be Prime Infrastructure 2.2, currently targeted for the September/October/November 2014 timeframe.
So if you have 1.4 or 2.2 then you can not upgrade and downgrade.
Thak you very much for your answers.
So we must :
1- make a fresh install of 2.1
2- re-insert on by one all the config that have been done on the 1.4
This is only the one workaround?
Hi Antra,
Yes this will take time but this is the best and as per my knowledge only way.
There is no upgrade path from version 1.4.x to version 2.0 it has to be done manually
