Upgrade wlc 2106 for mesh
s.henrot
I want to upgrade my WLC for meshing network. The last release is 4.1.192.22M but in the release note it's write 4.1.192.17M in the upgrade path ...
Another point is that the release 4.1.190.5 isn't present int the download section.
What's the path for the upgrade ?
dancampb
Level 7
Level 7
You can follow the upgrade path in the release notes. 4.1.185.0 - 4.1.190.5 - 4.1.191.24M - 4.1.192.22M.
I just checked and 4.1.190.5 is located under the Mesh Code link for the controller, All Releases, 4.1
