Upgrade Wlc's firmware with high-availability AP-SSO enabled
theophile
We want to upgrade two controllers (5508) in cluster with HA AP-SSO enabled. Could you please give me some recommandations before doing the upgrade? I do not know if all of the APs on the active Wlc will be automatically transfered to the standby one during the upgrade. As both wlcs are located on a critical site, I want to minimize the downtime and want to avoid any problem!
Thanks a lot for your advices
Theo
17 Replies 17
Use "reboot system both".
Depending on the firmware loaded in the controllers, both GUI and CLI will describe the progress of the upgrade.
5. After reload the pair, it doesn't work, doesn't start. What to do next?
Isn't the goal of the HA SSO not to reboot at the same time?
Not in the world of WLC.
Please open a new thread and add the following:
WLC model
Old and new firmware
LED state of the WLC
Any output when connecting a console cable to the WLC
