Upgrading WCS (Linux / WLSE) Problem
Richard Atkin
Level 10
Level 10
Hi All,
I've upgraded WLSE to WCS using the CD's supplied by Cisco, and that all went swimmingly, however they supplied WCS v4.0, and I need to run v4.1. So, I've downloaded the 4.1.83.0 bin file, and burnt it to CD, and have also uninstalled the old version of WCS Successfully, but when I come to install the new version of WCS, it all starts to go wrong!
1. log in to the CLI as root
2. mount /dev/cdrom /media/cdrom
3. cd /media/cdrom
4. ls (show the correct file name)
5. enter "./WCS-STANDARD-K9-4.1.83.0.bin"
and then I'm presented with an "Input Output Error", and subsequently am unable to install the new version of WCS.
I've tried the usual things like rebooting the box, mounting /dev/cdrom to a different directory, etc... but I always get the same error message.
I've looked through as many Cisco docs as i can find, but not been able to find anything about troubleshooting the installation process... Any help, much appreciated!
Thanks all..
ericgarnel
Level 11
Level 11
Try this:
mount the cd
cp WCS-STANDARD-K9-4.1.83.0.bin /tmp;
chmod a+x WCS-STANDARD-K9-4.1.83.0.bin;
cd /tmp;
ericgarnel
Level 11
Level 11
Try this:
mount the cd
cd /tmp;
Hi Eric,
I thought this very helpful info surely deserved my 5 points. Keep up the great work here! You have added some fine insight to these discussions.
Take care,
Rob
Thanks!
