08-05-2013 09:31 PM - edited 07-04-2021 12:35 AM
We had a problem with Virtual Machine which Cisco Virtual WLC installed. Virtual Machine files were damaged and the system was not start normally. We have had to reinstall the WLC, but after installation impossible to import current license to new one.
Old System SN : 93RT2xxxx
New System UDI : 923IUDPxxxx
How can i re-host the license to the new serial number.
08-05-2013 09:36 PM
08-06-2013 04:11 PM
As per your query i can suggest you the following solution-
Go to cisco.com/go/license and re-host the license.
Hope this will help you.
