03-11-2015 01:12 PM - edited 07-05-2021 02:41 AM
Can I use an 2702 AP with AIR-ANT2506 and AIR-ANT5160V-R anntenas?
03-11-2015 02:23 PM
2506 is 2.4 Ghz and 5160 is 5.0 Ghz. Both antennas are suitable for point-to-multipoint antennas. Sticking both into a single 2702 is not ideal and wouldn't be recommended.
Exactly what are you trying to achieve with this setup?
03-11-2015 03:03 PM
Hi Leo,
I need to install wi-fi network inside a wharehouse with high celling of 39 ft, there will be a few devices working in 2.4 Ghz. Testng with AIR-ANT2524DW-R dual band antennas seem to short signal range in 2.4 Ghz.
Thanks for your help.
03-11-2015 03:53 PM
1700/2700/3700 APs require dual-band antennas. Go HERE and scroll down to Tables 5, 6 & 7.
