Use CBS350 in ENT Wireless Network
Nader Elmansi
HI
Can I use CBS350 POE switches in ENT wireless network to connect WLC 9800L and C9105AXI
Is CBS switches support that connection and can work smoothly with CAPWAP and other wireless protocols and WLC functions
marce1000
  - You can't use CBS350  , and or small business wireless products on 9800 controller ,
 M.
Why not @marce1000 - looks to me like it supports all essential switch features?
https://www.cisco.com/c/en/us/products/collateral/switches/business-350-series-managed-switches/datasheet-c78-744156.html#Productspecifications
@Rich R My bad , indeed I was confused with the device being used as an AP (model) ,
 M.
Cool @marce1000 - so @Nader Elmansi you should be ok to use that switch for connecting your WLC and APs.  Obviously you need to make sure you have the right ports (fibre/copper) to match the WLC model you choose.
