Use WebAuth with wireless and wired LAN ?
Kai Onken
I've installed a Cisco Wireless LAN Controller (4402) with six access points (AIR-LAP1131AG-E-K9) and created two WPA2 protected  WLAN SSID's (e.g. internal and guest) and everything works fine.
The WLAN SSID named Guest, should be used for externel people. This SSID aditonal WebAuth. This also works fine, the guest receive a WPA2 key and username/password for WebAuthentication. But this works at this point only when they user WirelessLAN.
Now my Question:
Is it possible to provide the setup also to the wired network using the WLC?
Kind regards
