User idle timeout not working for wired
gudmundurk
Community Member
I have a 4400 wireless Lan Controller (4.2.99.0), I'm having a problem with users connecting with the wired connection and then disconnecting but the controller doesn't dispose of the session.
User Idle timeout is set to 300 seconds and works fine for the wireless part.. but seems it doesn't for the wired part.
If you have any tips, thanks.
drolemc
Level 11
Level 11
Did you run any debugs to find out if the controller is throwing any error message when the users are getting disconnected? Are you authenticating the users against a RADIUS server?
In that case, the radius server logs will also help. Please collect some debug outputs to troubleshoot this issue further.
Hi, thanks for the reply.
Cisco has notified me that this is a defect and they are looking into it, I'll let you know what comes out of it.
I did a detailed debug for the TAC case and sent it to Cisco.
Guðmundur
