User switching every few minutes between 2.4ghz and 5ghz
simon.dwyer
Hi All,
This  first started when a user said they were getting disconnected and  reconnected a few times a day to our wireless network.  He is in a  remote office with a 1142 which is set to H-Reap talking back to our  5508.  Our WLC is running 7.0.166
The laptop has an intel ulitmate 6300agn wireless card with the latest 15.x drivers.
We are using an SSID with wpa2 and 802.1x auth back to our ACS server using PEAP with our windows credentials.
attached is what i am seeing on the wcs troubleshooting page.
When i do a debug client on the WLC i see many reauthentications coming from the client on the different radio.
*apfMsConnTask_2: Aug 22 12:59:36.762: 00:24:d7:d1:16:6c Reassociation received from mobile on AP 0c:85:25:f3:7d:40
*apfMsConnTask_2:  Aug 22 12:59:36.762: 00:24:d7:d1:16:6c 10.24.8.108 RUN (20) Changing  ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller  apf_policy.c:1621)
*apfMsConnTask_2: Aug 22 12:59:36.762:  00:24:d7:d1:16:6c Applying site-specific IPv6 override for station  00:24:d7:d1:16:6c - vapId 512, site 'VH-GasWorks', interface  'management'
*apfMsConnTask_2: Aug 22 12:59:36.762:  00:24:d7:d1:16:6c Applying IPv6 Interface Policy for station  00:24:d7:d1:16:6c - vlan 2, interface id 0, interface 'management'
*apfMsConnTask_2:  Aug 22 12:59:36.762: 00:24:d7:d1:16:6c Applying site-specific override  for station 00:24:d7:d1:16:6c - vapId 512, site 'VH-GasWorks', interface  'management'
*apfMsConnTask_2: Aug 22 12:59:36.762: 00:24:d7:d1:16:6c STA - rates (8): 140 18 24 36 48 72 96 108 48 72 96 108 0 0 0 0
*apfMsConnTask_2: Aug 22 12:59:36.762: 00:24:d7:d1:16:6c Processing RSN IE type 48, length 38 for mobile 00:24:d7:d1:16:6c
*apfMsConnTask_2: Aug 22 12:59:36.762: 00:24:d7:d1:16:6c Received RSN IE with 1 PMKIDs from mobile 00:24:d7:d1:16:6c
*apfMsConnTask_2: Aug 22 12:59:36.762: Received PMKID:  (16)
*apfMsConnTask_2: Aug 22 12:59:36.762:      [0000] e0 79 8a 5f 4d 38 a0 52 b5 64 96 22 23 86 be 24
*apfMsConnTask_2: Aug 22 12:59:36.762: 00:24:d7:d1:16:6c Searching for PMKID in MSCB PMKID cache for mobile 00:24:d7:d1:16:6c
*apfMsConnTask_2:  Aug 22 12:59:36.762: 00:24:d7:d1:16:6c No valid PMKID found in the MSCB  PMKID cache for mobile 00:24:d7:d1:16:6c
*apfMsConnTask_2: Aug 22  12:59:36.762: 00:24:d7:d1:16:6c Trying to compute a PMKID from MSCB PMK  cache for mobile 00:24:d7:d1:16:6c
*apfMsConnTask_2: Aug 22 12:59:36.762: CCKM: Find PMK in cache: BSSID =  (6)
*apfMsConnTask_2: Aug 22 12:59:36.762:      [0000] 0c 85 25 f3 7d 40
*apfMsConnTask_2: Aug 22 12:59:36.762: CCKM: Find PMK in cache: realAA =  (6)
*apfMsConnTask_2: Aug 22 12:59:36.762:      [0000] 0c 85 25 f3 7d 4f
*apfMsConnTask_2: Aug 22 12:59:36.762: CCKM: Find PMK in cache: PMKID =  (16)
*apfMsConnTask_2:  Aug 22 12:59:36.762: 00:24:d7:d1:16:6c Unable to compute a valid PMKID  from MSCB PMK cache for mobile 00:24:d7:d1:16:6c
*apfMsConnTask_2: Aug 22 12:59:36.762: 00:24:d7:d1:16:6c Searching for PMK in global PMK cache for mobile 00:24:d7:d1:16:6c
*apfMsConnTask_2: Aug 22 12:59:36.762: 00:24:d7:d1:16:6c Found an entry in the global PMK cache for station 00:24:d7:d1:16:6c
*apfMsConnTask_2: Aug 22 12:59:36.762: CCKM: AA (6)
*apfMsConnTask_2: Aug 22 12:59:36.763:      [0000] 0c 85 25 f3 7d 4f
*apfMsConnTask_2: Aug 22 12:59:36.763: CCKM: SPA (6)
*apfMsConnTask_2: Aug 22 12:59:36.763:      [0000] 00 24 d7 d1 16 6c
*apfMsConnTask_2:  Aug 22 12:59:36.763: 00:24:d7:d1:16:6c computed a valid PMKID from  global PMK cache for mobile 00:24:d7:d1:16:6c
*apfMsConnTask_2:  Aug 22 12:59:36.763: 00:24:d7:d1:16:6c Creating a PKC PMKID Cache entry  for station 00:24:d7:d1:16:6c (RSN 0) on BSSID 0c:85:25:f3:7d:4f
*apfMsConnTask_2:  Aug 22 12:59:36.763: 00:24:d7:d1:16:6c Adding BSSID 0c:85:25:f3:7d:4f  to PMKID cache for station 00:24:d7:d1:16:6c
*apfMsConnTask_2: Aug 22 12:59:36.763: New PMKID: (16)
*apfMsConnTask_2: Aug 22 12:59:36.763:      [0000] e0 79 8a 5f 4d 38 a0 52 b5 64 96 22 23 86 be 24
*apfMsConnTask_2:  Aug 22 12:59:36.763: 00:24:d7:d1:16:6c 10.24.8.108 RUN (20) Deleted  mobile LWAPP rule on AP [0c:85:25:f3:7d:40]
*apfMsConnTask_2: Aug  22 12:59:36.763: 00:24:d7:d1:16:6c Updated location for station old AP  0c:85:25:f3:7d:40-0, new AP 0c:85:25:f3:7d:40-1
*apfMsConnTask_2: Aug 22 12:59:36.763: 00:24:d7:d1:16:6c apfMsRunStateDec
*apfMsConnTask_2: Aug 22 12:59:36.763: 00:24:d7:d1:16:6c apfMs1xStateDec
*apfMsConnTask_2: Aug 22 12:59:36.763: 00:24:d7:d1:16:6c 10.24.8.108 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_2: Aug 22 12:59:36.763: 00:24:d7:d1:16:6c 10.24.8.108 START (0) Initializing policy
*apfMsConnTask_2: Aug 22 12:59:36.763: 00:24:d7:d1:16:6c 10.24.8.108 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_2:  Aug 22 12:59:36.763: 00:24:d7:d1:16:6c 10.24.8.108 AUTHCHECK (2) Change  state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_2:  Aug 22 12:59:36.763: 00:24:d7:d1:16:6c 10.24.8.108 8021X_REQD (3) DHCP  required on AP 0c:85:25:f3:7d:40 vapId 512 apVapId 1for this client
*apfMsConnTask_2:  Aug 22 12:59:36.763: 00:24:d7:d1:16:6c 10.24.8.108 8021X_REQD (3)  Plumbed mobile LWAPP rule on AP 0c:85:25:f3:7d:40 vapId 512 apVapId 1
*apfMsConnTask_2:  Aug 22 12:59:36.763: 00:24:d7:d1:16:6c apfPemAddUser2  (apf_policy.c:223) Changing state for mobile 00:24:d7:d1:16:6c on AP  0c:85:25:f3:7d:40 from Associated to Associated
*apfMsConnTask_2: Aug 22 12:59:36.763: 00:24:d7:d1:16:6c Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_2:  Aug 22 12:59:36.763: 00:24:d7:d1:16:6c Sending Assoc Response to  station on BSSID 0c:85:25:f3:7d:40 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_2:  Aug 22 12:59:36.763: 00:24:d7:d1:16:6c apfProcessAssocReq  (apf_80211.c:5241) Changing state for mobile 00:24:d7:d1:16:6c on AP  0c:85:25:f3:7d:40 from Associated to Associated
*apfMsConnTask_2: Aug 22 12:59:36.807: 00:24:d7:d1:16:6c Updating AID for REAP AP Client 0c:85:25:f3:7d:40 - AID ===> 1
*dot1xMsgTask: Aug 22 12:59:36.862: 00:24:d7:d1:16:6c Initiating RSN with existing PMK to mobile 00:24:d7:d1:16:6c
*dot1xMsgTask: Aug 22 12:59:36.862: 00:24:d7:d1:16:6c Disable re-auth, use PMK lifetime.
*dot1xMsgTask: Aug 22 12:59:36.862: 00:24:d7:d1:16:6c dot1x - moving mobile 00:24:d7:d1:16:6c into Force Auth state
*dot1xMsgTask: Aug 22 12:59:36.862: 00:24:d7:d1:16:6c Skipping EAP-Success to mobile 00:24:d7:d1:16:6c
*dot1xMsgTask: Aug 22 12:59:36.863: Including PMKID in M1  (16)
*dot1xMsgTask: Aug 22 12:59:36.863:      [0000] e0 79 8a 5f 4d 38 a0 52 b5 64 96 22 23 86 be 24
*dot1xMsgTask:  Aug 22 12:59:36.863: 00:24:d7:d1:16:6c Starting key exchange to mobile  00:24:d7:d1:16:6c, data packets will be dropped
*dot1xMsgTask: Aug 22 12:59:36.863: 00:24:d7:d1:16:6c Sending EAPOL-Key Message to mobile 00:24:d7:d1:16:6c
        state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_4: Aug 22 12:59:36.912: 00:24:d7:d1:16:6c Received EAPOL-Key from mobile 00:24:d7:d1:16:6c
*Dot1x_NW_MsgTask_4:  Aug 22 12:59:36.912: 00:24:d7:d1:16:6c Ignoring invalid EAPOL version  (1) in EAPOL-key message from mobile 00:24:d7:d1:16:6c
*Dot1x_NW_MsgTask_4:  Aug 22 12:59:36.912: 00:24:d7:d1:16:6c Received EAPOL-key in PTK_START  state (message 2) from mobile 00:24:d7:d1:16:6c
*Dot1x_NW_MsgTask_4: Aug 22 12:59:36.912: 00:24:d7:d1:16:6c PMK: Sending cache add
*Dot1x_NW_MsgTask_4: Aug 22 12:59:36.912: 00:24:d7:d1:16:6c Stopping retransmission timer for mobile 00:24:d7:d1:16:6c
*Dot1x_NW_MsgTask_4: Aug 22 12:59:36.913: 00:24:d7:d1:16:6c Sending EAPOL-Key Message to mobile 00:24:d7:d1:16:6c
        state PTKINITNEGOTIATING (message 3), replay counter  00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_4: Aug 22 12:59:36.960: 00:24:d7:d1:16:6c Received EAPOL-Key from mobile 00:24:d7:d1:16:6c
*Dot1x_NW_MsgTask_4:  Aug 22 12:59:36.960: 00:24:d7:d1:16:6c Ignoring invalid EAPOL version  (1) in EAPOL-key message from mobile 00:24:d7:d1:16:6c
*Dot1x_NW_MsgTask_4:  Aug 22 12:59:36.960: 00:24:d7:d1:16:6c Received EAPOL-key in  PTKINITNEGOTIATING state (message 4) from mobile 00:24:d7:d1:16:6c
*Dot1x_NW_MsgTask_4: Aug 22 12:59:36.960: 00:24:d7:d1:16:6c apfMs1xStateInc
*Dot1x_NW_MsgTask_4:  Aug 22 12:59:36.960: 00:24:d7:d1:16:6c 10.24.8.108 8021X_REQD (3)  Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_4:  Aug 22 12:59:36.960: 00:24:d7:d1:16:6c 10.24.8.108 L2AUTHCOMPLETE (4)  DHCP required on AP 0c:85:25:f3:7d:40 vapId 512 apVapId 1for this client
*Dot1x_NW_MsgTask_4:  Aug 22 12:59:36.960: 00:24:d7:d1:16:6c 10.24.8.108 L2AUTHCOMPLETE (4)  Plumbed mobile LWAPP rule on AP 0c:85:25:f3:7d:40 vapId 512 apVapId 1
*Dot1x_NW_MsgTask_4: Aug 22 12:59:36.960: 00:24:d7:d1:16:6c apfMsRunStateInc
*Dot1x_NW_MsgTask_4:  Aug 22 12:59:36.960: 00:24:d7:d1:16:6c 10.24.8.108 L2AUTHCOMPLETE (4)  Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_4: Aug 22 12:59:36.961: 00:24:d7:d1:16:6c 10.24.8.108 RUN (20) Reached PLUMBFASTPATH: from line 4864
Now this may be not be the issue thats causing our dropouts a couple times a day as this is happening every 5 mins.
Any ideas would be brilliant.
Simon
12 Replies 12
Leo Laohoo
Duplicate post #2.
Amjad Abdullah
You can try disabling band select if that helps.
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70ccfg.html#wp1934253
Rating useful replies is more useful than saying "Thank you"
Do the clients have the latest driver installed?
The latest Intel updates are doing great!
simon.dwyer
Thanks for the ideas so far.  Already had Band Select disabled.
The driver is the latest 15.x from Intel still no luck.
Upgrading to the latest 7.0 code tomorrow morning and will see how that goes.
5508?  Go 7.2.110.0 instead.
Sadly we still have some 1230 AP so we cant go to 7.2 yet.  I am trying to get money to get them upgraded but wont be for a little while yet.
Saravanan Lakshmanan
this debug output is clean, get the debug when the issue gets reproduced.
Can you post how your wlan ssid is configured?
-Scott
fbarboza
Level 4
Level 4
Please post the configuration and let us know the WLAN with the issue.
If not make sure that the WLAN is set to braodcast the SSID, that it is configured to do wither WPA with TKIP or WPA2 with AES not both, then under the advance tab  make sure that you have disable aironet IE, session time out, client exclusion and MFP protection.
This is just to have a valid configuration and avoid any issues with the wireless clients connecting to the WLAN.
Also does the site where the issue have only has an access point or is there more than 1 access point managed by your WLC?
Hey,
Thanks for the tips.  I the only thing i had to change with your info is the aironet IE.  I have now disabled it and will see how i go.
The usecase i am atm only has one ap which we control.  We have had some complaints from some other users on another ssid, the only linking thing is that the ones that seem to have trouble are on H-REAP.
Following is the config for the ssid:
(Cisco Controller) >show wlan 512
WLAN Identifier.................................. 512
Profile Name..................................... Mulawa
Network Name (SSID).............................. Mulawa
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 8
Exclusionlist.................................... Disabled
Session Timeout.................................. Infinity
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
--More-- or (q)uit
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 75
DTIM period for 802.11b radio.................... 75
Radius Servers
   Authentication................................ 10.20.0.7 1812
--More-- or (q)uit
   Accounting.................................... 10.20.0.7 1813
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
CCKM tsf Tolerance............................... 1000
--More-- or (q)uit
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Enabled
   H-REAP Local Authentication................... Disabled
   H-REAP Learn IP Address....................... Enabled
   Client MFP.................................... Disabled
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
I would change your DTIM to 2, you have it at 75
-Scott
fbarboza
Level 4
Level 4
I wiould set the DTIM to 1 or 2 under the WLAN advince TAB.
