ā06-17-2013 11:39 AM - edited ā07-04-2021 12:14 AM
I have 2504 wlc, 1142n ap's and a windows radius server.
Users have figured out that they can connect their kindles to the wireless by using there network login credentials. How can I stop this? Change authentication from user or computer to just computer?
TIA,
Eric
Solved! Go to Solution.
ā06-17-2013 11:48 AM
You could lock down the number of concurrent logins each user can have.
on the WLC Security > User Login policies. Change from '0' which is unlimited.
other than that, you would need some device, like ISE, that can profile and deny access based on device type
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Hi Eric,
This is the challenge we are all seeing. You need to either implement an ISE solution or do a PKI with certificates. ISE allows you to ID devices and restrict kindles. Or a PKI solution where you need to install certs on devices with EAP-TLS.
__________________________________________________________________________________________
ā"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
ā06-17-2013 12:52 PM
There are many ways like what Steve an George mentioned. If you go away from user credential and use machine authentication, The devices have to be members of the domain in order for that to work. If you have devices that can't be a part of the domain, like Apple laptops, then like George mentioned, use certificates. Then the more expensive way is like Steve mentioned... ISE:)
Scott
Help out other by using the rating system and marking answered questions as "Answered"
ā06-17-2013 12:57 PM
A big Thank You! to all you guys! I am learning more here than I would in taking a class!!
ā06-17-2013 01:14 PM
Yeah... I've taken a share of classes and asked what the heck are they talking about:)
Scott
