Using Adminstration menu logging in C9800 GUI
abe-shinta
Frequent Visitor
Frequent Visitor
Hello , Professionals !!!
I have checked the C9800 GUI administration screen, Administration > Management > Logging.
It looks like I can set the “logging profile” here,
However, the setting was not reflected in the configuration, and there was no indication that logging was being output.
When will I use it?
PS:This screen was missing in the 17.13.1 release...
2 Accepted Solutions
Rich R
That page is for setting up export of logs to an external server.
If you're thinking of syslog that is set somewhere else:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-12/config-guide/b_wl_17_12_cg/m_syslog_server.html
This is what most people will be using.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Thank you for your response.
And Sorry for late my response.
I asked to Cisco TAC about this topics.
I received a response that this is not a feature that is not officially supported.
Therefore, there is no mention of it in the Config Guide and the feature appears to have been removed.
Rich R
