Using AIR-CAP2602I-A-K9 - cannot connect to wifi 5gh * channels from UNII 3 *
DanielV
Hello We have a corporate network where we facing some issues with the access point 2600 series .  . The problem is like this - The ap-s that are using  channels from UNII3 are not working for Corporate network but they can connect to GUEST network . They can see the SSID but they cannot use it . I changed manualy the channels and still have the same issue  .I have the same Access point model that are using diferent channel and for them everything is fine  I need to mentioned that all the user are using windows 10 .
Any ideea how to solve it ?
Thank you
8 Replies 8
Leo Laohoo
What firmware is the controller running on?
Hello
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
What version of WLC code?
Incorrect answer.
Post the complete output to the command "sh sysinfo".
WLC  is 5508
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.2.166.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Build Type....................................... DATA + WPS
System Name...................................... xxxxxxxxxxxxxxxxxxx
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. SSO
IP Address....................................... xxxxxxxxxxxxxxx
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 382 days 4 hrs 58 mins 11 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... Multiple Countries : AR,BR,MX,US
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +44 C
External Temperature............................. +36 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 340
Burned-in MAC Address............................ xxxxxxxxxxxxxxxxxx
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 500
System Nas-Id.................................... xxxxxxxxxxxxxxxxxxxxxxx
WLC MIC Certificate Types........................ SHA1
I'm going to say that this is the issue:  The WLC is configured with multiple countries that have conflicting 5.0 Ghz Regulatory Domain.
Regarding to this issue the problem started last week , until than everything was ok .   For example in 1 place i have 9 access point same model but they use diferent channels 8 are 9 and 1 not . Second location same problem . 90 % of the access poits are 2600 series . the stramge think is that i have some location where the ap-s are using a UNI-3 Channels and everything is woking fine .
i tryed to find the  issue with debug client from wlc . have no idea anymore where to get it .
Try upgrading the firmware of the WLC.
