Using multiple SSID with AP 1100 (standalone mode).
ROBERTO TACCON
Level 8
Level 8
Hi, need to configure 2 SSID on the same 1100 AP: open authentication and WPA2. It's possible to configure these 2 SSID without configuring VLAN's ?
On CCO I've read the following:
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_qanda_item09186a008009483e.shtml
Q. How many service set identifiers (SSIDs) can you have per VLAN?
A. You can have only one SSID per VLAN. The use of multiple SSIDs over a single VLAN is not supported with Aironet APs.
It's also true with the latest IOS release ?
Rob Huffman
Hi Roberto,
Hopefully the attached docs will answer your question:
Cisco Aironet 1100 Series
Using VLANs with Cisco Aironet Wireless Equipment
Deprecated versions of Cisco Aironet software permit binding multiple SSIDs to one VLAN. Current versions do not.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801d0815.shtml#
Cisco IOS Software Configuration Guide for Cisco Aironet Access Points, 12.2(15)JA
Configuring Multiple SSIDs
vlan vlan-id
(Optional) Assign the SSID to a VLAN on your network. Client devices that associate using the SSID are grouped into this VLAN. You can assign only one SSID to a VLAN.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_guide_chapter09186a00802085c4.html
Hope this helps!
Rob
Please remember to rate helpful posts.......
