Using scripts or batch files to configure APs on 5508 WLC
DRSessum1
Is there a way to use batch files to configure APs from Windows 7?  I have seen it done in Linux.  A batch file was written for setting up flexconnect mode and assigning APs, naming APs and assigning them to groups.
I have not found a method to do it in Windows.
d.friday
Level 4
Level 4
I suggest using Cisco Prime Infrastructure for management. It can do everything you. Are asking for.
