AIR-AP1852I-E-K9 Autonomous
Man29er
Hi. I just recently had shipped 4x of the above ap's I can't get them to add to our WLC AIR-CT5508-K9 v7.4.100 because of version incompatibility according to http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html and as we have a heap of 1240s I can only update so far. The error I'm getting on the WLC is;  #DTLS-3-HANDSHAKE_FAILURE: openssl_dtls.c:681 Failed to complete DTLS handshake with peer 192.168.x.x
So the questions are;
1) Can I make these autonomous? I've tried and tried but can't seem to get it to work or can they only be used as Mobility Express AP's?
2) Should these work with the WLC v 7.4.100.0, am I missing something? or what software version would work with both AIR-LAP1242AG-E9K9 and the above
Sandeep Choudhary
Yes you can convert it to Autonomus AP:
Activating it (turning the AP from lightweight to autonomous) is a single command.
Text
ap#capwap ap autonomous
***Once done, the lightweight IOS is DELETED from flash...
2) Should these work with the WLC v 7.4.100.0, am I missing something? or what software version would work with both AIR-LAP1242AG-E9K9 and the above.
1852 will not work with WLC version 7.4.100.0 because of this software compatibility as you mentioned in your posts.
And 1242 last SW support on WLC is 8.0.X means both AP(1242 and 1852) cant work together.
Dont forget to rate helpful posts
Thanks for the quick and helpful reply.. Unfortunately I don't have the "capwap ap autonomous" command available. Just the ones below..
#capwap ap
  erase                  Erase CAPWAP config
  ip                        CAPWAP ap ip command
  lag                      CAPWAP lag config
  primary-base      Configuring AP's primary controller
  restart                 Restart CAPWAP Protocol
  secondary-base  Configuring AP's secondary controller
  teritary-base        Configuring AP's teritary controller
Ohk then you need to use this method:
https://www.youtube.com/watch?v=SlOUH7E2css
https://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
https://supportforums.cisco.com/document/57476/lwapp-autonomous-conversion-and-vice-versa-access-points
well according to the youtube clip. I need a k9w7 image to make this autonomous. From the cisco site, I can only download Lightweight and mobility express for this model. So that would suggest it can't be made autonomous?
