Using WCS to compare WLC configurations
rhodrijenkins
Hi all,
I have a number of controllers which have been individually administrered and as a result the configurations are no longer uniform. Is there a WCS feature which will allow me to compare differences between the controller configs?
Many thanks
Rhodri
ericgarnel
Level 7
Level 7
Under WCS
Configuration Audit : controller-audit
Reports > Report Launch Pad > Compliance > Configuration Audit >
You can run reports on configurations.
Not sure if you can diff between controllers, but you can diff between WCS values and the controller(s)
The controller to controller diffs can be easily scripted via expect script
