Using WLC on 9300L connected as layer-2
Is it possible to use the wireless LAN controller in 9300L without enabling routing on it? The switch works as an access switch with multiple VLANs and is connected to an HP Core Switch.
Thanks.
Mark Elsen
 - That should work , if the controller serves multiple wlan/vlans then these must be terminated on the wireless management interface connection (on the 9300L) as a trunk port
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
