using WLSE to upgrade IOS
jlhainy
Level 2
Level 2
I just updated to WLSE 2.15.1 so I could use it to push out the 12.3(8)JEC IOS out to all of my 1210 AP's. While setting up the job, the WLSE gives a waring that the IOS I selected may not be for the AP I selected. I have confirmed that the IOS is the correct one for the AP. What gives?
andrew.brazier
Level 4
Level 4
It's the WLSE saying it doesn't recognise the IOS version as one it knows of and because of that it advised you that it might cause the AP to fail. If you've verified the IOS version matches the AP then you can safely ignore the message.
I figured as much. However, I just updated WLSE with 2.15.1 which is supposed to recognize that IOS. Maybe the 2.15.1 isn't all that it is cracked up to be. However, I did deploy the IOS in the middle of the night and everything went fine.
Thanks for the response.
