VACL Basics
Michael Sales
Level 2
Level 2
Hi All,
I've been working with ACL's for a while and needed to filter some iTunes share traffic on a specific VLAN
I assume VACL's will work for me. So, I created the following but it doesn't seem to be working.
Can I get some assistance on this from anyone who's done this more than I?
I'd appreciate it....
My intention is to block TCP 3689 and UDP 5353 that iTunes uses to share libraries.
Everything else is ok. This is enabled on a Cisco 4510 Core assigned to VLAN 100
ip access-list extended itunes
deny   tcp any any eq 3689 established
deny   udp any any eq 5353
vlan access-map stopitunes
action forward
match ip address itunes
action forward
vlan filter stopitunes vlan-list 100
---Show output--------------
4510-MDF#show access-list
Extended IP access list itunes
    10 deny tcp any any eq 3689 established (31006 matches)
    20 deny udp any any eq 5353 (1091101 matches)
    30 permit ip any any (659731373 matches)
Michael Sales
Level 2
Level 2
I think I may have found my problem.
I should have used a permit statement? then let the VACL action drop under the first match condition.
I missed that for some reason.
permit tcp any any eq 3689 established
permit udp any any eq 5353
action drop
action forward
I think this is what I should have configured...
I will check in a second.
