VCI String for LAP1232AG
benjamin.heron
Community Member
Sorry for my English, but I am French and I do not speak very quite English.
I will like to know which is the VCI string for an AP 1232AG to inform in the 43 DHCP Option.
Could you help me ?
Thank you
Ben
6 Replies 6
canghel
Level 2
Level 2
You can try to customize these settings for a Cisco Aironet 1240 Series AP:
Option 60 (VCI string): Cisco AP c1240
Option 43:
Type: 241 (decimal)
Length: Number of controller IP addresses X 4
Value: List of WLC management interfaces (typically translated to hex values)
Hope it helps,
Adrian
canghel
Level 2
Level 2
See attached document.
segopala
In fact, in this document, there is the VCI string for AP1240, but not for AP1230. So, I hope that is possible to use DHCP Option 43 with AP 1230.
Can you say some to me more ?
Hi Ben,
From what I know and have read the correct VCI string for the 1230 is;
Cisco Aironet 1200 Series;
vci string = Cisco AP c1200
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_quick_start09186a00805100f5.html
Migration from autonomous access point mode to lightweight mode is possible on these Cisco Aironet access point platforms:
All 1130AG access points
All 1240 AG access points
For all IOS-based 1200 series modular access point (1200/1220 Cisco IOS Software Upgrade, 1210 and 1230 AP) platforms, it depends on the radio:
if 802.11G, MP21G and MP31G are supported
if 802.11A, RM21A and RM22A are supported
The 1200 series access points can be upgraded with any combination of supported radios: G only, A only, or both G and A.
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00804fc3dc.html
Hope this helps!
Rob
Please remember to rate helpful posts.....
segopala
hi Ben ,
1230 belongs to 1200 group so you need to use
Cisco AP c1200 as VCI string .
Hope this will resolve your query
Seema
