Virtual wireless controller (vWLC) Installation on VMWARE ESXI 6.5
Rene MUGIRANEZA
Greetings;
I have spent more than 2 days searching on internet how to install vWLC on vmware ESXI 6.5 unfortunately nothing helpful was found.
Kindly, any documentation, requirements and step by step installation of vWLC on vmware ESXI 6.5 regarding to this will be appreciated.
Thank you.
omz
The process is the same as given here -
https://www.cisco.com/c/en/us/td/docs/wireless/technology/mesh/8-2/b_Virtual_Wireless_LAN_Controller_Deployment_Guide_8-2.html#id_10331
If you are having an issue with the ova file.. then you can try this ...
+ untar the ova file and upload .iso to the datastore
+ deploy ova file in esxi .. ignore ethe error
+ edit vm setting and just change the iso file on the cdrom to the one uploaded to vmware datastore.
+ reboot the vWLC and complete installation
balaji.bandi
here is the step by step help you to deploy the same :
https://ccieroot.com/2016/02/20/installation-of-virtual-wireless-controller-vwlc/
BB
