virtual wireless controller
Anukalp S
Level 7
Level 7
Hi.. i have running cisco vWLC controller in my location A, its working perfectly here. Now i have another location B where i have APs registered with controller in location A. I have created another WLAN and set location B dhcp server assign location B network ip. But issue is that when we connect to this wlan it gets connected but no ip gets assigned. wireless controlloer can reach to location B dhcp server, there is no connectivity issue b/w these.
what else settings do i need to set so that clients can get ip through dhcp.
Sebastian Pusta
Level 4
Level 4
Is location B WLAN configured with local or central switchinng?
If traffic is central switched (tunneled back to the WLC in location A) that may the problem in your case. I assume location A and B are in separate broadcast domains, so there should be an issue with the dhcp discovers from clients.
You should try to local switch the traffic for WLAN B or if it has to be central switched you should switch locally dhcp packets from clients.
abwahid
Level 9
Level 9
please go through the below link and check central switch configuration.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_flexconnect.html#wp1241304
Moin Ilyas
Level 8
Level 8
Please refer to the following link:
https://supportforums.cisco.com/document/98646/wireless-lan-flexconnect-configuration-example
gohussai
Level 8
Level 8
What i believe is that in your location B ,the AP is conencting over the wan if not then it must be on differnet subnet. You first check your WAN connectivity and also make sure you LAP is on flex connect mode and use Ip helper connect to get the IP from DHCP on location A.
