Virtual WLC in LAB environment
Lajja1234
Hi!
I have just installed a Virtual WLC at home for lab purpose. Now i want to connect one accesspoint to my wlc, but for now the WLC says "0 access points supported".
Can i somehow still use the evaluation licens and connect a accesspoint to the wlc?
/Lajja1234
Sandeep Choudhary
Hi Lajja,
You have to enable the evaluation license in order to allow the AP to join.
How to do it, please check here:
http://www.cisco.com/c/en/us/support/docs/wireless/virtual-wireless-controller/113677-virtual-wlan-dg-00.html
Hope it helps.
Dont forget to rate helpful posts
Sandeep Choudhary
Hi Lajja,
Hope it helps.
Rasika Nayanajith
Also note that vWLC only support FlexConnect mode AP. So if you have local mode AP you need to convert it to FlexConnect mode.
Rasika
**** Pls rate all useful responses ****
